08-07-2008, 07:25 PM
Suggest me a Branded External HDD (160 GB)
Hi Friends
I'm planning to buy a USB External HDD (160 GB).
Suggest me a Good Branded External HDD Drive. My budget is Rs. 2000
Regards
Yoda
08-07-2008, 08:25 PM
The Frozen Nova
Re: Suggest me a Branded External HDD (160 GB)
I don't think you would get an external HDD for this less. You can instead buy a laptop HDD and go for a usb casing. That would fit in your budget.
If you want a proper external HDD and can increase your budget, then I would suggest that you go for a Western Digital external HDD
www.nerdweed.blogspot.com
08-07-2008, 11:46 PM
Point Blanc
3300 with tax WD Elements 160 GB(no need of external power).
You need to check the costs of 80 GB and 120GB, they would be in your expectations near 2000, otherwise I do not know about power supply based externals.
10-07-2008, 03:41 PM
Thanks for the replies casanova and acewin.
I've a few doubts ???
1. which Brand should I choose Seagate or WD. Which one is good, reliable and portable. I travel a lot with the External HDD.
2. The External HDD I use now is a Normal HDD + enclosed in a casing(Gemini), but Its malfunctioning frequently. What is the difference between the Branded External HDD and the converted ones (Nornal HDD + casing) ? Are they both the same or different.
10-07-2008, 04:17 PM
TechTin.com
Increase your budget and get a WD
10-07-2008, 05:08 PM
Lets Do It!
Go for Seagate ....
Its a name u can trust.
But for 160 GB , u need to increase ur budget .
"Now you're looking for the secret... but you won't find it, because you don't really want to know. You want to be fooled."
10-07-2008, 07:23 PM
thanks for the replies. Surely I'm increasing the budget and I'm planning to get a 160 GB External HDD.
Please suggest a model name or model name and price of the WD External HDD (160 GB) or Seagate External HDD that is reliable, tried and trusted.
10-07-2008, 08:59 PM
Seagate -- More problems WD -- Less warranty. Choose.........
10-07-2008, 09:19 PM
And Maxtor has shock-protection!
10-07-2008, 10:06 PM
TechTin.com
WD have home service...and external portable HD have 3 year warranty.
10-07-2008, 10:15 PM
Google Bot
WD Passport
11-07-2008, 03:44 PM
The Frozen Nova
Welcome yoda.
WD is the way to go. No competition IMHO
16-07-2008, 06:33 PM
What is the cost of 160GB WD Passport
16-07-2008, 06:38 PM
TechTin.com
Rs. 3500/- rs. 4000/-
16-07-2008, 06:44 PM
M3TAL H3AD M3
there are tech com pocket hdd for 2.5k about 80 gig
not great material although
I spit Rainbows.
16-07-2008, 07:17 PM
segate free agent is also an option ...but it is a bit expensive but steady
17-07-2008, 02:57 AM
Point Blanc
ok I come again with the price, bcoz last friday my roomy and another friend bought WD Element 160 GB. would come in 3200 including taxes.
and 250 GB will come 5K including taxes.(both price for WD Element model which is silver coloured)
WD Passport is Rs 400-500 costlier both in 160GB and 250GB.
Difference is Passport is black in color and element is silver colored and has rubber on the edges which is good. Secondly passport has bundled softwares.
I recommend Elements. But both the models from WD are great. I too carry around my external alot much. and one more thing Element seems to be lighter(in weight) than passport.
I would not recommend Free Agent becausse its costlier. And I see the WD servicing has been very much recommended, so 3 year warranty is good.
