Originally Posted by Cool G5
It will support SATA DVD writer for sure, it has two sata ports.
Yeah and why not get normal ones?
SATA
IS the normal one today. Never get IDE ones if you can help it. The lone IDE slot in today's mobos supporting two IDE drives is best used for emergencies and if you need to connect an IDE Drive from your older rig to it.
SATA over IDE is as recommended as getting Core2Duo E7200 instead of Core2Duo E4600. Its simply a better more future proof option.
Apple iPad 2 16GB WiFi
