Old 08-07-2008, 07:13 AM   #1 (permalink)
Stay Silent!
enticer86's Avatar
Default Urgent advise needed
Hello frnds.
My current config. is
Intel Celeron CPU 2.00Ghz (original chipset) with Intel 845Dglly series MOBO
512 MB RAM (properties show 504MB)
WinXP SP3
My father told me he wants to get it updated. Would it b advisable to get Dual Core? I mean would it actually improve speed considerably?
Also pls advise whatever possible.
I saw me running,
'Twas a long, long run.
But the view was so stunning,
And that made it so much fun... ©
enticer86 is offline
Old 08-07-2008, 11:46 AM   #2 (permalink)
Deadman Walking
Batistabomb's Avatar
Default Re: Urgent advise needed
Originally Posted by enticer86 View Post
Hello frnds.
WinXP SP3
first tell what's your budget
What looks to be nothing,finally that becomes everything...
and what is everything suddenly that changes to nothing...
Learn to live... &
Live to learn...
Batistabomb is offline
Old 08-07-2008, 11:55 AM   #3 (permalink)
Do you want to change processor only or graphic card and memory as well? Budget?
ThinkFree is offline
Old 08-07-2008, 12:14 PM   #4 (permalink)
Stay Silent!
enticer86's Avatar
Budget 7-10k
I use the computer for basic work- Excel, a lil bit of graphics, and primarily internet usage.
I saw me running,
Old 08-07-2008, 02:58 PM   #5 (permalink)
For the works you have mentioned, even this configuration is good enough. Just upgrade memory to 1GB.
Old 08-07-2008, 04:57 PM   #6 (permalink)
jebasingh85's Avatar
I do have a 845 chipset mobo. Is it possible to pair it with a Dual Core cpu?
"It's a Lion, It's coming... It's coming... And It's a Lion" - Opening lines of the song 'THE LIONKING - Circle of Life.
jebasingh85 is offline
Old 09-07-2008, 10:23 AM   #7 (permalink)
Deadman Walking
this was the correct choice i thought you might go for complete system upgrade, so only change your RAM,also i can advise you to change your monitor to an LCD if you don't have one
Learn to live... &
Live to learn...
Old 09-07-2008, 04:28 PM   #8 (permalink)
Stay Silent!
enticer86's Avatar
Sorry for the delay
Finally got :
Intel Premium Dual CPU
E2180@ 2.00GHz
1.99GB RAM
Physical Address Extension
Whats Physical Address Extension???
Reason for upgrade? You all will know in a few days
I saw me running,
Old 09-07-2008, 04:36 PM   #9 (permalink)
Bond, Desi Bond!
desiibond's Avatar
Sorry for the delay
Finally got :
E2180@ 2.00GHz
1.99GB RAM
Do you really think that we want to know reason for your PC upgrade??
and btw, it's not Intel Premium Dual CPU
It's Intel Pentium Dual Core CPU.
desiibond is offline
Old 09-07-2008, 04:46 PM   #10 (permalink)
Stay Silent!
enticer86's Avatar
I kno its Dual core, but i just copied what the system properties said.
I saw me running,
Old 10-07-2008, 09:58 AM   #11 (permalink)
Deadman Walking
you will find this only in intel pentium pro versions which defines your RAM limit, in your case you can upgrade up to 4GB RAM, according to your operating system specifications
Learn to live... &
Live to learn...
Old 10-07-2008, 11:23 AM   #12 (permalink)
Cool Buddy's Avatar
He did not want you to notice core, he wanted you to notice pentium, you had written premium.
Nokia 5230 :(
Canon IXUS 115 HS :)
Cool Buddy is offline
Low budget cellphone-advise needed. enticer86 Mobiles and Tablets 1 12-06-2008 11:47 AM
Advise Needed MR.MOUSTACHE Hardware Q&A 14 13-01-2008 01:29 AM
Decision for buying branded p.c.Advise needed. harpoon Hardware Q&A 5 02-05-2007 02:30 PM
Urgent help needed kau_therock QnA (read only) 20 11-12-2004 09:23 AM
Tv tunercard: Advise needed sanjaykulkarni QnA (read only) 13 02-08-2004 12:22 PM
