Old 07-07-2008, 05:24 PM   #1 (permalink)
Fullbring
Zangetsu's Avatar
Question Hardware failure...
Hi,
What are the symtoms of hardware failures....
1) CPU failure
2) RAM failure
3) Graphics Card failure
4) PSU failure
5) Mobo failure
6) HDD failure
Zangetsu is offline
Old 07-07-2008, 05:41 PM   #2 (permalink)
Rebooting
Choto Cheeta's Avatar
Default Re: Hardware failure...
PC doesnt work
anyway, read this..
http://www.chotocheeta.com/2007/12/1...tart-up-beeps/
rebooting
ChotoCheeta.com
Choto Cheeta is offline
Old 08-07-2008, 12:52 AM   #3 (permalink)
The sypmtoms depend on whether it's a partial or a complete failure. Except for the HDD, with complete failure of any of the other components, you will not get a bootup screen at all. Partial failure can produce a variety of symptoms such as unexpected restarts, corrupt display, hangs, freezing, etc.
pimpom is offline
CRC Failure prajantika Software Q&A 2 23-05-2006 12:33 AM
S.M.A.R.T Failure q3_abhi QnA (read only) 2 02-06-2005 11:35 AM
Power Failure, What should I do? pradipudhaya QnA (read only) 11 16-05-2005 09:24 AM
FDC Failure shyam911 QnA (read only) 2 25-03-2005 08:22 PM
