Old 06-07-2008, 09:07 PM   #1 (permalink)
mortal kombat
quan chi's Avatar
Default dual core query.please post your suggestions.
hi friends.
well i have mobo asus p5gl-mx which has cpu socket LGA 775 and i have intel p4 3.0 ghz with ht installed in it.well its two years old.
so my query is if in future i want to upgrade to a dual core.will i be able to install that dual core in the same mobo.or i have to change the entire mobo.as i have seen dual core also require LGA775 socket.
please do reply.
quan chi is offline
Old 06-07-2008, 09:29 PM   #2 (permalink)
At Hell's Disq
hellgate's Avatar
Default Re: dual core query.please post your suggestions.
ur current mobo doesnt support any of the dual cores (C2D or Dual core).so u need to change ur mobo if u wanna change ur peocy to dual core.
hellgate is offline
Old 06-07-2008, 10:23 PM   #3 (permalink)
mortal kombat
quan chi's Avatar
well then what about the sockets.
please do reply.
quan chi is offline
Old 07-07-2008, 05:18 AM   #4 (permalink)
The Smaller Bang
MetalheadGautham's Avatar
I suppose your mobo could run Pentium D. So if you get hold of a cheap sub 2K pentium D, and if your system is otherwise satisfactory, upgrade to it. But performance will still suck to Core2 architecture.
Apple iPad 2 16GB WiFi
MetalheadGautham is offline
wats diff between dual core n core 2 duo reddevil2 Hardware Q&A 8 25-07-2009 10:27 AM
frames per second query.please post your suggestions. quan chi Hardware Q&A 6 29-04-2008 09:09 PM
AMD dual core optimizer query. john_the_ultimate CPU / Motherboards 2 27-10-2006 04:13 PM
Intel dual core without HT or AMD64 dual core--which is best vps85 CPU / Motherboards 2 26-04-2005 01:02 AM
