Old 04-07-2008, 09:18 PM   #1 (permalink)
Default CM 460W - Enough juice?
I was looking to purchase the CoolerMaster Extreme Power Plus 460W for my rig which consists of C2D e7200,Geforce 9600GSO,DDR2-800 on a abit ip35e.
I know it is enough under normal circumstances, but would it be able to handle a 20-30% overclock of each of these components.
I guess if I do need to step up, it would be either the CM 500W or POV Black diamond 500W since the Corsair VX450W is out of my budget.
But then since I would be sticking with this config without any upgrade for at least another 2 years, do suggest an upgrade if absolutely necessary since any amount saved helps me to divert it to other hardware.
t3chg33k is offline
Old 04-07-2008, 09:37 PM   #2 (permalink)
Alter Bridge=GOD
nish_higher's Avatar
Default Re: CM 460W - Enough juice?
Yes this psu can handle ur rig nicely .i've used this on my quad for a while and its pretty stable.i think anyone not opting SLI should look for this.and u can check a review for how good this is in overclocks too
Apple Macbook Pro 17 :cool:
nish_higher is offline
Old 04-07-2008, 11:43 PM   #3 (permalink)
Google Bot
Pathik's Avatar
But to be on the safer side and contemplating a GPU upgrade, you should go for the CM Xtreme 600W. 3.1k
Pathik is offline
Old 05-07-2008, 11:38 AM   #4 (permalink)
I would be sticking with this rig for 2 years if not more and there would be no upgrades during the course, hence I suppose the CM 460W would do for now.
I do realise though that in the future any upgrade would be accompanied by a PSU upgrade as well, but I guess its one for the future.
Thanks guys.
t3chg33k is offline
Old 05-07-2008, 11:51 AM   #5 (permalink)
damn busy...
utsav's Avatar
i am also getting this psu for my system. its gives the best bang for the buck
any1 knows its exact price??
MSI GX660 with ATI 5870 :grin: ultimate gaming lappy :grin:
Dell Studio 15(1555)
1TB+1.5TB external|N86|ZTE Blade|5230|E63|EP-630|Soundmagic PL50|Sennheiser CXL 400|Meelec M11P+
www.techjunkiez.com
utsav is offline
Old 05-07-2008, 12:31 PM   #6 (permalink)
Alter Bridge=GOD
1900 buckss..CM RS-460-PCAR-A3
only this one has a 8 pin CPU connector (4+4pin)
Old 05-07-2008, 03:23 PM   #7 (permalink)
Hmm... to keep a margin of safety I suppose I would go with the CM 500W.
What should be the price I should expect at Lamington Road ~Rs.2500-2600?
@utsav
It is necessary to check that it is the PCAx version and not the PSMx version since both are different designs and feature different components,fans and connectors.
Also keep in mind to purchase Extreme Power Plus and not Extreme Power.
t3chg33k is offline
laptop dvd drive + orange juice ishaan Laptops and Netbooks 6 29-11-2005 04:24 PM
How to Juice up Doom3 sushir Gamerz 10 24-04-2005 03:34 PM
