Old 04-07-2008, 01:36 AM   #1 (permalink)
Default Connecting Sata DVD rom to PCI
My MB is the ASUS M2N MXSE. It has only two Sata ports. When i brought my computer, I installed a Samsung Sata HDD 160 GB and a Samsung Sata based DVD Writer. Now, i want to install a SATA 250 GB HDD but there are no SATA ports left. In hindsight, i should have installed an IDE based DVD writer. Now, what options do i have? Should i discard the Sata based DVD writer, and replace it with an IDE based one, or should i buy a SATA card. I am a newbie, and i dunno how the latter works. Will it be compatible with my MB. Which is the cheaper alternative? Also, tell me which SATA card should I buy. Price is a issue, cant afford very costly alternatives which exceeds the price of DVD writer itself. Is it easily available in Delhi
Please help...very urgent
Saurav2007 is offline
Old 04-07-2008, 02:17 AM   #2 (permalink)
Seed is the Life!!
shift's Avatar
Default Re: Connecting Sata DVD rom to PCI
buy a IDE SATA or SATA IDE converter...............
can convert IDE to SATA or SATA to IDE
plug the converter to ur HDD, then put IDE cable to converter and the other end of IDE cable to your motherboard
cost Rs.200 here in BANGALORE, dont know in Delhi
u can easily get from any computer shop
Stupidity Causes Cancer !!
shift is offline
SATA ROCKS : Fujitsu intros first 2.5" 7200 rpm hard drive with SATA 2.5 interface techtronic Technology News 7 22-03-2009 11:09 PM
Sata-II hard disk working at Sata-I mode Arsenal_Gunners Hardware Q&A 27 17-03-2009 10:18 PM
Connecting a SATA n Pata together HELP hmvrulz Hardware Q&A 12 04-08-2007 02:14 AM
(HELP) connecting 2 sata n optical drives demondementia Hardware Q&A 1 13-04-2007 10:09 PM
Can I attach a new sata drive to my existing Seagate 80GB SATA HDD? praka123 Hardware Q&A 6 04-02-2007 06:28 PM
