Old 03-07-2008, 06:40 PM   #1 (permalink)
Default Need to recover data from a corrupt drive
Ok, this is going to sound stupid What happened was a friend wanted to get something off my HD, and he had this antiquated P3, 256 MB setup. I have a 80 GB HD. So when I connected my HD his computer hung, Ctrl+Alt+Del didn't work, and he disconnected the HD
When he did this, Windows gave an error message "Delayed write failure" and after that when I plugin my HD I get a error message saying "G:\ is not readable. The file or directory is corrupted and unreadable".
So is there anyway to recover my data? I'm willing to spend time figuring out how to.
Thanks =)
karan129 is offline
Old 03-07-2008, 07:29 PM   #2 (permalink)
Alter Bridge=GOD
nish_higher's Avatar
Default Re: Need to recover data from a corrupt drive
i think it just might show up in linux,in case u have a live cd of any linux.otherwise u'd need some data recovery soft,which i think ain't free.there's a demo of r drive.check it.
Apple Macbook Pro 17 :cool:
nish_higher is offline
Old 03-07-2008, 07:44 PM   #3 (permalink)
Point Blanc
besides what nish says. only readable area of HDD can be recovered. Area gone cuckoo, cannot be recovered. running the HDD as a secondary HDD with Linux OS is your best option. Besides it will work if it gets detected by XP as a secondary drive. without any recovery software also. and if you are using recovery S/W, do not plug your HDD before installing the software and and only after 2nd reboot.
Some recovery softwares may also clear your HDD if you just add before installing. That is why I say add your HDD only on 2nd reboot of the install of the S/W
acewin is offline
Old 04-07-2008, 06:35 PM   #4 (permalink)
Thanks, it always good to get pr0 advice ^^ I tried a recovery software and I'm getting some data back, but w/o names and in fragments, not in whole files.
karan129 is offline
Old 04-07-2008, 10:10 PM   #5 (permalink)
smile's Avatar
Wink Re: Need to recover data from a corrupt drive
Try PC Inspector
SR
smile is offline
Nee help to recover HDD data brweb Hardware Q&A 4 01-02-2008 02:21 PM
Recover Data from NTFS Drive redhat QnA (read only) 1 08-12-2007 09:48 AM
What Softwares/techniques data recovery professional use to recover data from HDD ? CadCrazy Software Q&A 1 10-08-2007 10:01 AM
How to recover data from DVD-RW??? go4saket QnA (read only) 12 23-02-2007 11:54 PM
Recover corrupt BIOS sagargv Hardware Q&A 1 28-01-2006 09:10 AM
