Old 03-07-2008, 03:29 PM   #1 (permalink)
Good Boy
george101's Avatar
Question HDD Bad Sector!!!
i hav a 120GB Seagate IDE HDD with me and it has bad sectors in it... i tried to fix them using built in check disk in XP and also using HDD regenarator but to no avail... i then tried using check disk with "recover bad secors" and nw i can use the hdd... i hav a doubt... during scanning it showed correcting file system and something like tat... so if i format the hdd will i hav to check disk again or is the dhh permanently fixed???? Plz reply...
george101 is offline
Old 03-07-2008, 05:29 PM   #2 (permalink)
RexRazr's Avatar
Default Re: HDD Bad Sector!!!
as bad sector is a physical problem of HDD...so softwares (like chkdsk with recover bad sector command) can only make the HDD temporarily usable by putting those damaged sectors aside...so ur HDD can arise problem again anytime...try low level formatting once when u'll format...if it still becomes unusable again then try chkcsk again...but i doubt if it'll make the HDD usable again...it's best to get the HDD replaced if it's within the warranty period
AMD X2 6000+@3.2GHz | XFX nForce 8200 HybridSLI | 4 GB 800 MHz DDR2 | XFX 8800 GT 512 Alpha Dog XXX | Seagate 320 GB Barracuda + Hitachi 250 GB DeskStar | Cooler Master Extreme Power Duo 600 Watts
RexRazr is offline
Old 04-07-2008, 07:51 PM   #3 (permalink)
Fast 'N' Furious
topgear's Avatar
I had ran onto same prob.
Send your HDD for replacement.
ToPsPeEeD = FaSt BuT StEaDy
topgear is offline
Bad Sector recovery?? cypher Hardware Q&A 5 25-03-2009 03:25 PM
Help got a bad sector CA50 QnA (read only) 12 06-10-2007 10:44 AM
How to remove Bad Sector cyberplanet Hardware Q&A 14 10-06-2006 07:44 AM
Bad Sector ????? Problem ashishsingh_bhatia Hardware Q&A 6 03-02-2006 10:58 PM
Bad Sector mahesu_87 QnA (read only) 7 07-07-2005 09:26 AM
