Re: BIOS Boot failure
is it necesary to remove the battery before changing jumper settings ?
i always thought battery is reqd for the jumper change to take place. i mean where else do you get the power from when comp is off.
correct me if anything is wrong .
or maybe ram might have come off or there might be a loose contact.
S. B. F. defines me.
http://prashantmaxsteel.blogspot.com
Chemistry and Computer is my world.
Appy Fizz is my drink.
Alchemist,Angels & Demons is what i read.
Reason: Automerged Doublepost
