Originally Posted by aswin1
Check your monitors manual to see if it supports that resolution.
Previously i was using "1280x1024" resolution only sir! There was no problem But suddenly i got this wavy things
Originally Posted by s18000rpm
change the "refresh rate".
the onboard gfx. cant handle that level of resolution.
so either stick to lower resnl. or buy a gfx. card.
But i used that higher resolution for a year, and there was no problem. i got this problem suddenly. When i use lower resolution, i can notice changes like, the face of actor are becoming somewhat conical. it's not like the previous one! and sir, i am using the lowest refresh rate of 60 Hz only.
My question is whether there's problem with my monitor or my graphics card?
