Old 02-07-2008, 07:43 PM   #1 (permalink)
Dishant's Avatar
Default xfx 8600gt not working
8600gt not working
hello guys,
my xfx 8600gt crad is showing as "Standard VGA graphics adapter" in Device Manager. i mean i can not install it's drivers bcoz it says no such hardware found.i can not run Aero also. Even in xp it's not working now.
the problem came after i installed my new WD 320 gb Hdd. but it's working absolutely fine.
the monitor is attached to the card.
pls help...
thanks in advance
My system Specs are : asus m2n-vm dh mobo......amd 4200+......4x1gb 667 kingston ram.
Dishant is offline
Old 02-07-2008, 08:14 PM   #2 (permalink)
Rebooting
Choto Cheeta's Avatar
Default Re: xfx 8600gt not working
If you are getting the display while the DVU is attached to the card mean its working !!!
Download latest driver from Nvidia.com web site http://www.nvidia.com/object/winxp_175.16_whql.html
and then try to install, see what happens, if still no success then try a OS clean installation also
rebooting
ChotoCheeta.com
Choto Cheeta is offline
Old 03-07-2008, 10:49 PM   #3 (permalink)
Super Moderator
asingh's Avatar
Try to reseat the GPU. And yes...do install latest drivers..!
asingh is online now
What to do with my 8600GT SLI?? Harvik780 Hardware Q&A 26 25-09-2008 02:21 PM
Help on xfx 8600gt codeguru Hardware Q&A 1 14-11-2007 01:49 AM
8600GT 256MB or 8600GT 512MB? Sreeejith Hardware Q&A 53 29-10-2007 07:54 PM
8600GT or 8600GTS or 8600GT Fatality bajaj151 QnA (read only) 31 12-08-2007 08:38 PM
