Old 01-07-2008, 09:32 PM   #1 (permalink)
Good Boy
george101's Avatar
Cool C2D + Mobo = 10k
hi guys... am going to sell my existing C2D E6300 1.8Ghz and Intel DG965SS (1 year Old) for around 7.5k and i want to buy a new C2D+Mobo for 10k... plz specify which one shud i go for... and does this will have any performance improvement over my current config????
george101 is offline
Old 01-07-2008, 11:41 PM   #2 (permalink)
At Hell's Disq
hellgate's Avatar
Default Re: C2D + Mobo = 10k
for 10k:
E7200 - 5.5k
abit IP35-E - 5.3k.
8600GT 256MB GDDR3 - 3k (if u dont hav a gfx card already,then u'll hafta spend 13k instead of 10)
hellgate is offline
Old 02-07-2008, 07:36 AM   #3 (permalink)
moshel's Avatar
firstly think why you want to upgrade?
if its for gaming then just put in a graphics card. u will get a good performance upgrade.
moshel is offline
Old 02-07-2008, 08:24 AM   #4 (permalink)
Good Boy
george101's Avatar
i hav 8600gt 256mb gddr3... its tat my current proc is only 1.8ghz and i thot upgrading will hav much performance boost... and is 7.5k good deal for my current config...
Old 02-07-2008, 03:06 PM   #5 (permalink)
At Hell's Disq
hellgate's Avatar
^^^ u can always get a abit IP35-E and use wit ur current procy.then u can easily oc it to 3.2GHz.
hellgate is offline
Old 02-07-2008, 06:17 PM   #6 (permalink)
Good Boy
george101's Avatar
wat??? overclock 1.8 to 3.2GHz........
can an amd proc + mobo at 10k beat my current config
Old 02-07-2008, 09:51 PM   #7 (permalink)
At Hell's Disq
hellgate's Avatar
^^^ yup buddy C2Ds oc like hell.i've oc'd my E8400 from 3Ghz to 4.05Ghz (see my siggy.).
with better 3rd party cooling u can oc even higher.
if u oc ur C2D then no AMD setup in 10k will beat urs.
u wont believe but my E8400 @ 4.05GHz beats the hell out of most Phenom Tricores and quads.
hellgate is offline
Old 03-07-2008, 10:20 AM   #8 (permalink)
Good Boy
george101's Avatar
but then i wud hav to change my mobo and ram as am using dynet 2x1gb 667Mhz.... wat shud i do??? change them and oc C2D or change my setup to amd???
Old 03-07-2008, 10:32 AM   #9 (permalink)
At Hell's Disq
hellgate's Avatar
ram is ok u dont need to change it.just run in 1:1 for dram:fsb ratio.
hellgate is offline
Old 03-07-2008, 12:04 PM   #10 (permalink)
Good Boy
george101's Avatar
but i hav another problem... here in kerala most vendors havnt even heard of abit... i asked many shops and many dealers but of no avail... can u plz giv me contact address of an abit dealer here in kerala....
if u cant help me with tat, then cud u plz specifyy another mobo for 6k which supports good oc and also an e-sata port???
Old 03-07-2008, 02:20 PM   #11 (permalink)
At Hell's Disq
hellgate's Avatar
u can always buy online from www.theitware.com
else try for MSI or Asus or Gigabyte.
hellgate is offline
Old 03-07-2008, 03:17 PM   #12 (permalink)
left this forum longback
praka123's Avatar
@george: ask noveon or online IT or positive systems in Kochin for abit boards.
praka123 is offline
Old 03-07-2008, 03:42 PM   #13 (permalink)
Good Boy
george101's Avatar
if i buy online wat abt warranty.. hw can i avail it if some problem occurs???
Old 03-07-2008, 04:00 PM   #14 (permalink)
Caballero de Real Madrid
m-jeri's Avatar
@prak.....
does noveon deal with abit and evga too???
if they do please give full addres with phone...
|PC-15R-i3 M530|3GB DDR3|320GB|5470 512MB|500 GB Ext|D/L-D410PT|1GB|500GB|E122|APEX MI - 100|A/V-E2200HD|PS3 80GB+AT90USB162|Z5500 D|10TB|MOMO Wheel|APC 1KV|Click-500D|18-55 IS|
m-jeri is offline
Old 03-07-2008, 05:23 PM   #15 (permalink)
Point Blanc
besides itwares can you suggest some other online stores also from where we can get products.
correcting the link set by hellgate ITWARES
acewin is offline
Old 04-07-2008, 11:09 AM   #16 (permalink)
Good Boy
george101's Avatar
thanks acewin for ur siggy
which mobo to go for spartan2k7 Hardware Q&A 4 10-06-2007 01:32 AM
Mobo for D 930 ...help!!!! ArZuNeOs Hardware Q&A 6 29-06-2006 10:19 AM
MSI mobo or INTEL mobo pls. help karthik316_2003 CPU / Motherboards 10 29-05-2005 03:29 PM
mobo and cpu AGENT_SMITH CPU / Motherboards 15 19-03-2005 11:05 AM
pci-e mobo for amd 64.. prankzter CPU / Motherboards 23 24-02-2005 07:50 PM
