Old 01-07-2008, 04:40 PM   #1 (permalink)
Alive Again...
satyamy's Avatar
Question Laptop Shutdown unexpectedly and Fan not working properly
Hi,
I have a Compaq Presario V2000
It is heating very much and shutdown Unexpectedly
Its Fan is not running
But, When I switch on the Laptop fan starts for a sec or two but after this it stops and dosent run, If i blow some air from my mouth it starts running and works fine
but it dose not start automatically as it should be when I switch on my Lap
I have also tried some software upgrade and BIOS update from HP sites which say
"Fixes intermittent issue where fan does not operate correctly" from here http://h10025.www1.hp.com/ewfrf/wc/s...roduct=1136345
but was of no use
What can be the Prob is their Prob with Fan or batter or any other Hardware or Software Prob ?
Please Help
! जय हिंद ! Proud to be INDIAN
satyamy is offline
Old 01-07-2008, 04:46 PM   #2 (permalink)
Fahd.Malik's Avatar
Default Re: Laptop Shutdown unexpectedly and Fan not working properly
Have u tried cleaning the fan?
My desktop Cpu fan gives this kinda problem once in 4-5 months, and it works fine after cleaning and if needed i pour a single, very little drop of machine oil.
Well that works for me
Fahd.Malik is offline
Old 01-07-2008, 04:47 PM   #3 (permalink)
Alive Again...
satyamy's Avatar
ya tried but was of no use
satyamy is offline
Old 02-07-2008, 12:50 AM   #4 (permalink)
RexRazr's Avatar
how long have u been using ur lappy? maybe the thermal paste between the fan and the procy is gone...if so then u gotta apply it again
AMD X2 6000+@3.2GHz | XFX nForce 8200 HybridSLI | 4 GB 800 MHz DDR2 | XFX 8800 GT 512 Alpha Dog XXX | Seagate 320 GB Barracuda + Hitachi 250 GB DeskStar | Cooler Master Extreme Power Duo 600 Watts
RexRazr is offline
Old 02-07-2008, 10:46 AM   #5 (permalink)
Alive Again...
satyamy's Avatar
its is 1.5 year old
wht is the relation between fan and thearmal paste ?
bcoz if thearmal paste is gone than Proc should heat up and shutdown
but here proc is heating up bcoz of not running of Fan and if i blow some air from my mouth the Fan Starts and Lap dosent Shutdown
but every time blowing air from mouth is a kind of sensless and weired thing if i use it somewhere outside home
So pls tell me some possible reason ? and way ?
satyamy is offline
Old 02-07-2008, 11:08 AM   #6 (permalink)
Rebooting
Choto Cheeta's Avatar
U know any hardware guy around ? as Open up the lappy clean the fan also a careful drop of oil may require
but some one having knowledge of these thing should open the lappy chasis !!!
rebooting
ChotoCheeta.com
Choto Cheeta is offline
Old 02-07-2008, 01:59 PM   #7 (permalink)
Alive Again...
satyamy's Avatar
I hav myself already done that
opened the Lappy, Cleaned the Fan
this is the same fan i found inside lappy
but their was not much dust also
after cleaning the prob is continue
I also used this BIOS Update, which says
but was of no use
also i thought to try to change the Fan
but it is too coslty comes for 99$ i.e. $99 x 42 = Rs. 4128
so i can only change it if I am sure that it is Fan's Prob, if that is something other than their is a big loss
satyamy is offline
Old 02-07-2008, 03:03 PM   #8 (permalink)
dhanusaud's Avatar
Replace CPU fan. . . .
I faced the same problem few weeks ago with my tx1302au, now solved.
my blog http://www.dhsthemes.blogspot.com
themes for symbian phones
dhanusaud is offline
keyboard not working properly saurabh kakkar Hardware Q&A 3 09-07-2007 12:30 AM
Help-Pendrive not working properly!! rajivrocks Software Q&A 11 16-03-2007 01:15 AM
DVD drive not working properly.. windchimes Hardware Q&A 4 04-07-2006 08:17 PM
dev c++ compiler not working properly..... tweety_bird_bunny Programming 3 30-07-2005 08:38 PM
CD Rom Drive not working properly Tech&ME QnA (read only) 6 17-11-2004 01:04 AM
