Old 01-07-2008, 09:09 AM   #1 (permalink)
Träît¤r$_¥ll_$üffêr
bodyquest's Avatar
Default am2\am2+ motherboard!
HI!
guys plz suggest a good motherboard to overclock a am2 cpu 4800+.....
.....should have plenty of overclock options and should b stable....
.....future proof.....must support future batch of phenom am2+...that tlb-fixed thingy!
.....should b under 5.5k!
.....don't want sli\xfire.....
.....ATX FORM FACTOR!.....no m-atx
.....no onboard gfx
thanx!
bodyquest is offline
Old 01-07-2008, 09:49 AM   #2 (permalink)
SKA!'s Avatar
Default Re: am2\am2+ motherboard!
try this :
http://www.gigabyte.com.tw/Products/...=GA-MA78GM-S2H
Pentium 4 2.4 GHz (northwood 478 sockets), VIA p4m266, 768 DDR 133 MHz RAM, Nvidia 5200 FX AGP 256 MB, Local cainet + 350 watt smps, LG 700s Studioworks 17" CRT,80 GB Samsung PATA..need an upgrade ;)
SKA! is offline
Old 01-07-2008, 02:57 PM   #3 (permalink)
Träît¤r$_¥ll_$üffêr
bodyquest's Avatar
@above :
...i dont need onboard gfx .....i will not use as i have 8800gt....previously had 8600gt ....
come on guys!
Old 02-07-2008, 07:47 AM   #4 (permalink)
Make Way the LORD is Here
ssk_the_gr8's Avatar
look for a good board based on amd 770+ SB750(prefrebaly.. otherwisw SB700 will do) mobo if u want it for cheap. otherwise go for 790x or 790 fx with SB750..
id suggest try MSI
Plz give ur budget.. only then can i suggest something.
(Gen.1:26-27) New Testament
FORUM RULES - Updated
Don't Buy from Sulekha
ThinkDigit Forum Workspace Showoff Contest
ssk_the_gr8 is offline
Old 02-07-2008, 09:38 AM   #5 (permalink)
Träît¤r$_¥ll_$üffêr
bodyquest's Avatar
id suggest try MSI
well i have already written in clear words but u seems to ignore my main post and post ur thoughts...........well any ways .....actually u should try to reread my first post......
hey guys!
Old 02-07-2008, 10:55 PM   #6 (permalink)
hey ididnt read ur post properly.. my mistake..
i suggest u try to get a a board with SB700 cuz they OC better
this one has onboard graphics .. but is a good overclocker
http://www.asus.com/products.aspx?l1...70&modelmenu=1
http://www.msicomputer.com/product/p...M-FIH&class=mb
you can also check this board...no on board gfx
http://www.newegg.com/Product/Produc...82E16813138102
http://www.asus.com/products.aspx?l1=3&l2=149&l3=592
but the best i think u can get in ur budget with a SB700 is
http://www.foxconnchannel.com/produc...D=en-us0000369
http://www.foxconnchannel.com/produc...D=en-us0000370
both these have the cheaper chipset amd 770... if u are able to get a amd 790x in 5.5k then you should definetly consider it as it should OC better.
BTW , i have a friend who has got 25% overclock on his 4600+ .. at standard cooling on asus m3a.... but i still suggest you go for foxconn's amd 770 chipset cuz it has SB700.
Old 09-07-2008, 07:27 PM   #7 (permalink)
here's a review....
http://www.bit-tech.net/hardware/200...rboard-duel/11
Motherboard for P4 HT dhanusaud Hardware Q&A 8 23-02-2008 07:37 PM
Motherboard Help!!! jatin931 Hardware Q&A 7 26-12-2007 04:31 PM
motherboard for amd x2 kooabs03 Hardware Q&A 2 22-05-2007 09:19 PM
which motherboard ?? h_phalak Hardware Q&A 1 04-09-2006 12:09 AM
Motherboard parimal_xp2003 CPU / Motherboards 4 22-06-2005 12:05 AM
