Old 01-07-2008, 12:37 AM   #1 (permalink)
Default Pen Drive shows unknown device
When I connect my, Pen drive its shows device not recognized, but when I disconnect and connect it gets connected.
girishrn is offline
Old 01-07-2008, 12:56 AM   #2 (permalink)
Krazy_About_Technology's Avatar
Default Re: Pen Drive shows unknown device
You telling this to everybody or are asking for help lol
sorry no offenece yaar, what OS are you running? if its an old computer with XPSP2, it happens sometime due to damaged/dusty USB ports. If you r running a new computer, try obtaining the latest service pack for your OS (SP1 for Vista, SP3 for XP). I am saying this coz these service packs contain a newer version of USBSTOR.sys, the universal driver for USB mass storage devices.
If you are running linux, please try sending PM to one of the Linux Gurus here i am not one of them, though i use it.
Dell Inspiron 1525 - C2D 2 Ghz, 3GB, 250GB, X3100 :)
Samsung Omnia Pro B7610 with Stock WM 6.1 ROM
Blog: http://www.sumitbhardwaj.co.in/blog
Krazy_About_Technology is offline
Old 01-07-2008, 10:37 AM   #3 (permalink)
I tried in new computer also but then also it shows device not recognized.
girishrn is offline
Old 01-07-2008, 01:41 PM   #4 (permalink)
ECE0105's Avatar
If it connects on the second attempt, try formatting the drive and check if that fixes it.
Try formatting it from CMD. That should fix it.
If you are using Win 98 (hope not)... you would have to install the drivers. But for XP and/or Vista, it should work fine.
If it is not getting detected at all on multiple systems, time to throw it away and buy a new one... last heard, Transcend 2GB is for 350 Rs.
Also, scan the PC for any virus Pen drives these days, seem to be infected with too many.. avast seems to be best in detecting these....
Some of the happiest people in the world do NOT have Everything... They just make the Best of Everything life brings their way... So, Stay HaPpY.... Smile Always.... :-)
ECE0105 is offline
Old 01-07-2008, 02:43 PM   #5 (permalink)
yes, my friend had the same problem....he was using vista..i asked him to install sp1 and then it started working....also, use a good antivirus like nod32 or even the latest avg free ver 8.
apoorva84 is offline
How to connect a usb device which the win xp says as UNKNOWN DEVICE? aQi_g Software Q&A 8 03-07-2008 03:59 PM
!!! Unknown Device !!! navino87 QnA (read only) 4 21-10-2006 05:01 PM
Windows shows Harddisk as Safely removable device. mantahn Software Q&A 4 31-03-2006 07:24 PM
Flash drive shows bad sector polu Hardware Q&A 1 12-03-2006 01:19 PM
pen drive shows less capacity... gauravakaasid QnA (read only) 2 25-07-2005 11:18 AM
