Old 30-06-2008, 01:48 PM   #1 (permalink)
BlackBerry Guru ! :)
BBThumbHealer's Avatar
Wink LG 29" TV Set & GeForce 8600GT
Hello Guys ,
Today i was connecting my LG 29" Flat TV to my CPU using the S-Video Out on my GeForce 8600GT...Now when i start up my CPU with the TV connected in AV Mode , i am able to see the whole process of booting up quite clearly , but as soon as it gets over , now when the logon screen has to appear , the TV just goes blank with just 2-3 horizontal white lines ! What can be the problem ? Do we have to tune thru the nVidia Control Panel ! My PC's running on both Windows XP & Windows Vista !
Any help wud be highly appreciated !
Thnx
BBThumbHealer !
Username Changed - BlackBerry7100g To BBThumbHealer ! :D
BBThumbHealer is offline
Old 30-06-2008, 05:25 PM   #2 (permalink)
Rebooting
Choto Cheeta's Avatar
Default Re: LG 29" TV Set & GeForce 8600GT
8600 GT means you should have the nvidia control panel that is what is used in your system to manage dual display setup
please right click in your desktop and click nvidia control panel
now in the control panel left navigation look for option multiple display and set it up as per your need via on screen instruction
rebooting
ChotoCheeta.com
Choto Cheeta is offline
Old 30-06-2008, 05:29 PM   #3 (permalink)
First of all , Gr8 to see u back Choto !
Only the option of " Only use one display ( single ) " is displayed ! Now what ?
Old 30-06-2008, 05:31 PM   #4 (permalink)
Rebooting
@BBThumbHealer
a screen shot would be helpful
Also bro, there in multi display setup one option be there for "My Display not shown in the list"
use that to bring force detection of your TV display
rebooting
ChotoCheeta.com
Last edited by Choto Cheeta; 30-06-2008 at 05:59 PM. Reason: Automerged Doublepost
Old 01-07-2008, 02:04 PM   #5 (permalink)
i don't disconnect my cable cord in the television when i plug in my CPU , can that be the reason ?
Old 01-07-2008, 02:09 PM   #6 (permalink)
Rebooting
Sorry but didnt understand the mean !!!! can u please explain ??
rebooting
ChotoCheeta.com
Old 01-07-2008, 06:32 PM   #7 (permalink)
i meant that when i switch to the AV mode , the cable wire is still connected to my television set ! that means , i can switch b/w the PC and Cable simultaneously by just pressing a button on the remote
Do i need to disconnect the cable wire from my television set before starting my CPU ?
Old 01-07-2008, 06:52 PM   #8 (permalink)
Alpha Geek Banned
bikdel's Avatar
^^^ no that isnt your problem.... Cable wire has nothing to doo with AV input ..
I'm not a GEEk, i still use Windows!
bikdel is offline
Old 01-07-2008, 11:33 PM   #9 (permalink)
Rebooting
+ 1
Did you try the force detection ??
rebooting
ChotoCheeta.com
Old 01-07-2008, 11:46 PM   #10 (permalink)
dattebayo
anispace's Avatar
it should work fine without any additional settings. Even i often connect my CPU (geforce 8400gs) to my 29" Sony Wega. It gets detected automatically. When i open the nvidia cp with my tv connected it shows TV as displays currently connected.
Try connecting the TV only and not the monitor.
Yoda: No. Try not. Do... or do not. There is no try.
anispace is offline
Old 02-07-2008, 10:13 AM   #11 (permalink)
ok ... . will try to bring in the force detection of television and post the results !
Overclocking Geforce 8600GT parimal_xp2003 Overclocking 18 09-06-2008 10:56 AM
Will my motherboard support GeForce 8600GT arun77574 Hardware Q&A 23 09-09-2007 03:37 PM
