Old 30-06-2008, 11:54 AM   1 links from elsewhere to this Post. Click to view. #1 (permalink)
Ashok Verma's Avatar
Exclamation LG CRT Monitor problem.
Hi friends please help!
From a few days i'm facing a strange problem with my 17" CRT LG 700E monitor.
it does not start when i switch on my PC. it takes about 4-5 min. after starting PC..
i have check the power cord. and even replaced it...
it works fine after it gets start.
i noticed that when i turn on my ups(power) without starting PC. The LED to the right side near power button Blinks very faster than the usual speed.
i think there is no problem with OS.
what could be the possible cause and solution to this problem
I am using windows XP professional
CPU intel 3.06GHz
Mobo intel 865GSA
1.5GB RAM
80GB HDD
sony DVD-RW
Ashok Verma is offline
Old 30-06-2008, 12:19 PM   #2 (permalink)
dhanusaud's Avatar
Default Re: LG CRT Monitor problem.
CRT blip.
OLD CRT buddy you should prepare to get new TFT.
Anyway, just turn off & on the monitor when it blinks very fast more than as usual.
my blog http://www.dhsthemes.blogspot.com
themes for symbian phones
dhanusaud is offline
Old 07-07-2008, 04:06 PM   #3 (permalink)
Originally Posted by dhanusaud View Post
CRT blip.
This is the last option i would prefer. anybody please suggest some alternative. should i really need to replace my CRT
Old 07-07-2008, 04:25 PM   #4 (permalink)
smile's Avatar
Talking Re: LG CRT Monitor problem.
Hm...........give it to service
SR
smile is offline
LinkBack to this Thread: http://www.thinkdigit.com/forum/hardware-q/91779-lg-crt-monitor-problem.html
Thread CRT monitor problem | Tech Support Forum | BoardReader This thread Refback 01-09-2010 02:54 PM
MOnitor problem! rohus24 Hardware Q&A 5 25-10-2006 10:40 AM
Monitor Problem cooldip10 Hardware Q&A 2 04-09-2006 04:51 PM
MONITOR PROBLEM( in 17'') nittn_only_4u1 Hardware Q&A 2 23-01-2006 06:12 PM
Monitor Problem karan_khilery QnA (read only) 4 10-06-2005 07:35 PM
Monitor Problem hikapil QnA (read only) 7 31-03-2005 07:45 PM
