Old 30-06-2008, 02:59 AM   #1 (permalink)
Simply a DIGITian
krishnandu.sarkar's Avatar
Default HDD Getting Hotter.............Plz Suggest
Hey frndz...............I do dwnld whole nite............but my problem is my hdd gets very hot even I can't touch the lower part...................but other components do not get hot so much. Is this normal for a hdd??? Plz suggest as soon as u can. I keep one side of my cabinet always open.
  • Read The Forum RULES First.
  • Before PM'ing Or Asking Any Questions To Any Mod Read The FAQ's
  • Before Starting A New Thread Read The STICKY THREADS First
  • Before Participating In Bazaar Section Read The BAZAAR RULES
krishnandu.sarkar is offline
Old 30-06-2008, 03:02 AM   #2 (permalink)
I did it all for d n00ki3
sibot's Avatar
Default Re: HDD Getting Hotter.............Plz Suggest
Hard disks are meant to get hot, but if you find it getting extremely hot, I would suggest you use a Hard Disk cooler fan. Its available in the market and helps keeping your hard disk cool. But I really don't think it should be a problem since hard disk heating is quite normal. Overheating affects CPU mostly. You can also download a hard disk temperature monitor tool to keep a check on your hdd.
Intel Core2Duo E4400 - 2Ghz | Asus P5B-MX Motherboard | 2 GB DDR2 RAM, 410 GB HDD | 8500 Nvidia Geforce XFX | Creative Audigy 2 ZS | iCool 480W | DVD-RW(Sata)
www.compmart.in
sibot is offline
Old 30-06-2008, 03:10 AM   #3 (permalink)
Rebooting
Choto Cheeta's Avatar
read the sticky post in hardware section Overheating problems
now try and get your self few cabinet fans, if cabinet supports the 120nn or if not then smaller 90mm or such
Rs. 30 for the smaller cabinet fans in Chadni incl 4 screw
rebooting
ChotoCheeta.com
Choto Cheeta is offline
Old 30-06-2008, 06:03 AM   #4 (permalink)
cooldip10's Avatar
@krishnandu.sarkar: Have you seen it on some temperature monitoring software??
Everything is Possible
cooldip10 is offline
Old 30-06-2008, 07:56 AM   #5 (permalink)
Be CoOl rAp RuLeZ !!!
krates's Avatar
if you have got a intel mother board they provide you with one temp monitoring software
iPhone 3G 16GB + Samsung I450 + Sennheiser CXL 400 + PSP Phat + Samsung NC10 :D
Previous phones: N73ME , W810I , Asus P320
krates is offline
Old 30-06-2008, 12:57 PM   #6 (permalink)
ax3
Cool as a CUCUMBAR ! ! !
ax3's Avatar
new hdd`s tend 2 get hotter faster ....... place on an ICE slab ..... haha haha .....
use some xtra fans ..... & check ur connections also .......
... W H O T ...
ax3 is offline
Old 30-06-2008, 10:59 PM   #7 (permalink)
Simply a DIGITian
thnx frndz..................fr suggesting..............
Old 01-07-2008, 12:02 AM   #8 (permalink)
iL6>Tushar
linux_ubuntu's Avatar
HDD should be at 38'c to 40'c check your airflow in your cabby, buy nice CFM fans
linux_ubuntu is offline
Old 01-07-2008, 12:08 AM   #9 (permalink)
हॉर्न ओके प्लीज़
victor_rambo's Avatar
offtopic: I have purchased a small table fan exclusively for cooling my HDD. I have removed both the side coverd of my cabinet and my fan points to my HDD and processor.
Also I have not kept my cabinet in the small space that is provided for it. That small space just prevents ventilation.
गीक होना माँगता
victor_rambo is offline
Old 01-07-2008, 01:40 AM   #10 (permalink)
Simply a DIGITian
i dwnlded a sftwr for measuring temp...........it's currently showing my HDD temp as 50C
Old 01-07-2008, 07:26 AM   #11 (permalink)
cooldip10's Avatar
that temp. is too high for any hard disk..
Mine remains around 38-42 C.
Check your ventilations properly and try keeping it clear...
Old 01-07-2008, 11:51 AM   #12 (permalink)
हॉर्न ओके प्लीज़
Also check that the SMPS(power supply) fan is working properly. May be that if it fails, it hampers the circulation of hot air from SMPS and thus indirectly hampers ventilation around the HDD.
गीक होना माँगता
Old 02-07-2008, 03:59 AM   #13 (permalink)
Here Since 2003
Indyan's Avatar
Thread Moved
My Blog :: http://www.pallab.net
Twitter :: http://www.twitter.com/indyan
Indyan is offline
Suggest Me..........ECE or CSE or IT?? SUKHI99 Chit-Chat 9 26-08-2007 06:14 AM
Suggest for a new pc Tech$oft QnA (read only) 1 17-08-2007 09:10 PM
Is 3000+ hotter than 4200+ ? dOm1naTOr Hardware Q&A 39 03-09-2006 02:59 PM
suggest un QnA (read only) 4 14-05-2005 05:06 PM
