29-06-2008, 06:43 PM
हॉर्न ओके प्लीज़
Is my RAM DDR 1 or DDR 2? [more info inside]
Hi guyz,
Update: I found that RAM is DDR 1. So which brand/company should I buy?(
Click here for that post)
I cannot figure out if my existing RAM is DDR 1 or DDR 2. All I find is a label on the RAM that reads:
MDGBL4F3G38AODICO2
DDR 333(2.5) 256Mx8
S/N: 510TH(BLBDB1808)
[1] So it that DDR 1 or 2?
[2] If its DDR 1, can I get DDR 2 or vice-versa?
[3] Whats the approximate cost of DDR 1 and 2 of 256 and 512 MB in Thane(near Mumbai)
System config:
2.4 GHz Intel P4
256 MB RAM
80 GB HDD
Thank you
-Rohan
गीक होना माँगता
29-06-2008, 06:53 PM
Re: Is my RAM DDR 1 or DDR 2? [more info inside]
Hi ,
Try using CPUz
www.cpuid.com/cpuz.php
i am sure it will show the correct result.
29-06-2008, 06:59 PM
[1] most likely , ddr1. try cpuz.
[2] nope.
[3] 512mb ddr1 may cost about 900 bucks
29-06-2008, 07:49 PM
हॉर्न ओके प्लीज़
Thanks Malik and Sagar,
Here is the CPU-Z report. I think its DDR 1.
Thanks
गीक होना माँगता
29-06-2008, 08:25 PM
Legen-wait for it-dary!
[1] You have a DDR1 ram.
[2] Nope, a motherboard can support either DDR1 or 2, not both.
[3] Dunno, sorry.
29-06-2008, 08:42 PM
Alter Bridge=GOD
Originally Posted by rohan_shenoy
Hi guyz,
MDGBL4F3G38AODICO2
DDR 333(2.5) 256Mx8
System config:
2.4 GHz Intel P4
256 MB RAM
80 GB HDD
Thank you
-Rohan
1.definitely ddr1
2.no..
3.512 mb would cost 1000 bucks and 256 mb isnt available i think.if it is it might cost 500-600 bucks
Apple Macbook Pro 17 :cool:
30-06-2008, 12:41 AM
हॉर्न ओके प्लीज़
Thanks Dheeraj and Nish. I will get one tomorrow probably
गीक होना माँगता
30-06-2008, 01:27 AM
Google Bot
333mhz is ddr1. Always.
30-06-2008, 01:39 AM
The Smaller Bang
DDR2 starts at 400MHz. So this HAS to be only DDR1.
Apple iPad 2 16GB WiFi
01-07-2008, 01:37 AM
हॉर्न ओके प्लीज़
Thanks Pathik and Metal  .....M getting one tomorrow.....will post in the 'What you bought' thread tomorrow
गीक होना माँगता
01-07-2008, 01:52 AM
Rebooting
Thanks Pathink and Metal  .....M getting one tomorrow.....will post in the 'What you bought' thread tomorrow
Off Topic
Just asking whats the full config bro ? and being a Linux user would u really need more ram by investing in an obsulate technology ??
rebooting
ChotoCheeta.com
01-07-2008, 01:56 AM
Google Bot
Pathik, BTW.
01-07-2008, 07:29 AM
Dreamweaver
AFAIK, 400 or less than 400 MHz is always DDR1
01-07-2008, 11:29 AM
हॉर्न ओके प्लीज़
Originally Posted by Pathik
Pathik, BTW.
Thanks
Ok, I had just been to the store here and he quoted me Rs. 800 for 512 MB and Rs. 1650 for 1 GB of Transcend. Is the price correct? Should I buy it?
Another store quoted almost similar price for Dynate(or is it Dynet?) RAM. I had heard that Dynate RAMS are to be avoided.
So should I buy Transcend?
Thanks for your patience guyz.
गीक होना माँगता
01-07-2008, 12:05 PM
In a New flavour
No actually 512 available in 700 and 1 GB in just 1300 in Chennai for transcend
Dont by it.
Life Grows Best, When Deciplined
01-07-2008, 10:13 PM
333Mhz is ddr mate.2.5 is the latency. ie pc2700 go for hynix man ... they are the best...
