Old 29-06-2008, 05:03 PM   #1 (permalink)
Spiff's Avatar
Arrow Router hunting...n Ram latency
Hello!
i m planning to buy a router ....fr my ADSL connction..
Should i go fr a 'n' or nt ... althogh my laptp has a Broadcom 802.11 b/g WLAN
Which one to go fr.? Shall i stick wid the digit test dis month... or suggest sum other??
my budget 4000 bucks... n can be extended...
secondly, i want to knw wat xactly ram latency is???
Spiff is offline
Old 30-06-2008, 02:38 AM   #2 (permalink)
Unmountable Boot Volume
Cyrus_the_virus's Avatar
Default Re: Router hunting...n Ram latency
Get an Aztech Wireless router for Rs1900/-. I use if for my business, no problems! and easily configurable, one of the best user interfaces. This is only a router and not one with an Inbuilt ADSL modem. You can use this only if you already have a Modem.
You don't need to bother about ram latency as long as you're not an overclocker or an avid gamer trying to get every bit of performance out of the hardware.
Webhosting for Rs12/month!!
http://www.thinkdigit.com/forum/showthread.php?t=74717
http://www.outpowerhosting.com
Cyrus_the_virus is offline
Old 30-06-2008, 02:24 PM   #3 (permalink)
Spiff's Avatar
what xactly RAm Latency is...???
i dont knw.... pls clarify
Spiff is offline
Old 30-06-2008, 04:38 PM   #4 (permalink)
The time between initiating a request for a character in memory until it is retrieved. If the data are not in the cache, it takes longer to obtain them.
harmads is offline
Old 13-07-2008, 08:30 PM   #5 (permalink)
Spiff's Avatar
Arrow Re: Router hunting ...pls reply asap...
Pls reply which router should i go for....
i m going to buy one this week....my budget Rs. 4000 (can b extended)
pls quote the cost too..
Spiff is offline
Old 13-07-2008, 08:38 PM   #6 (permalink)
maddy_in65's Avatar
You should go for Netgear DG834G. It is a good router.
maddy_in65 is offline
Queries regarding Latency of RAM sainit Hardware Q&A 7 28-05-2007 11:00 PM
CAS latency of the ram which one should I buy? ranjan2001 Hardware Q&A 19 19-01-2007 11:10 PM
Microsoft Ships New Malware Hunting Utility saipothuri Technology News 5 12-11-2006 06:20 PM
What is CAS Latency in RAM hotdogXP Hardware Q&A 1 28-01-2006 03:08 PM
Changing the CAS latency of RAM???? yesh_1683 QnA (read only) 2 17-03-2005 06:58 PM
