Old 28-06-2008, 06:59 PM   #1 (permalink)
Smile Zebronics Lava Prob
Hi guys...
i hav zebronics lava cabinet and asus p5n-mx motherboard.....
in the front panel led(lava) the power led(blue in colour) is constantly blowing even the total power is switched off..... can anyone solve out this problem..?? plzzz
saamonsan is offline
Old 28-06-2008, 07:14 PM   #2 (permalink)
RexRazr's Avatar
Default Re: Zebronics Lava Prob
there's leakage somewhere in the power cable junctions...and don't tell me that those LEDs are glowing even if u pull the psu plug off the main or the ups lolz
AMD X2 6000+@3.2GHz | XFX nForce 8200 HybridSLI | 4 GB 800 MHz DDR2 | XFX 8800 GT 512 Alpha Dog XXX | Seagate 320 GB Barracuda + Hitachi 250 GB DeskStar | Cooler Master Extreme Power Duo 600 Watts
RexRazr is offline
Old 01-07-2008, 07:45 AM   #3 (permalink)
there is no leakage n al... its a new one... bios n everything works fne... except the audio... can u suggest several ways of installing the audio... plz...
Old 01-07-2008, 03:39 PM   #4 (permalink)
RexRazr's Avatar
which audio are u talking about...to activate the front audio panel of your cabinet or to activate your onboard audio?
to activate the onboard audio...just go to bios and eable it from there (it should be enabled by default)
and to activate the front audio panel...u need to plug in the 9 pin female socket (which u'll find somewhere inside ur cabinet) to the front panel audio male connector in your mobo (refer to ur mobo manual...u'll find it there)
RexRazr is offline
Need help with Zebronics Lava Cabinet avikchaks Hardware Q&A 7 28-09-2008 05:45 PM
Help With Zebronics Lava Cabinet lyamunan QnA (read only) 3 03-06-2008 09:04 PM
where can i buy Lava Lamp in delhi ?? saurabh kakkar Chit-Chat 10 13-05-2008 01:23 PM
abt Zebronics Bijli??? ramsingh QnA (read only) 1 27-03-2008 04:11 PM
Zebronics one sufficient ? XtremeFuturistic Hardware Q&A 7 08-03-2007 11:31 PM
