28-06-2008, 05:26 PM
9800 GTX for 12,000 !!!
hey guyz check this out:
http://www.nvidia.co.in/HelpMeChoose...asp?lang=en-in
set the range between 11,000 to 12,000 and see what result comes......
looks like nvidia has decided to drop prices of 9800 GTX but i guess it will take time to filter down to us. how many weeks acc to u ppl?
also plz suggest me a PURE gaming rig for max 50k
TY
28-06-2008, 06:27 PM
Linux all the way
Re: 9800 GTX for 12,000 !!!
hey but what about the graphics memory. and is that possible in at this moment, coz 8800 is retailing at higher price...
28-06-2008, 06:36 PM
Hw abt ecs 8800gt 512mb fr 145$ new egg:-P
e8400 / abit ip35-E / gskill 4gb / mx5021 + audigy 2zs / Visiontek 4870 / corsair vx450 / Dell E198wfp
28-06-2008, 07:20 PM
@Vishal
its standard 512 gddr3...click on the graphics cards in the list for details. Dunno why 8800GT is costlier though, but i guess that nvidia is going for a ATI/AMD Radeon 4850 kill with 9800GTX....
though AMD has won the performance war according to reviews on anandtech.com n other review websites, it may lose in price war.
@johnjjx
ya bro...thts gud news 4 consumers  , i only wish newegg and other budget sites had presence in India.
Abt my comp query.I am planning to go to Lamington Rd, Mumbai (about 6 hrs frm Nasik,3 dealers here quoted 13-14k for a q6600,so i got the point)for buying parts, any suggestions about haggling are welcome
heres what i think will suite my needs:
proc : E8400 (8.5k)
mobo : abit ip35e or asus P5k (dunno abt abit service) (7.5K)
Gpu : 8800GT(or 9800GTX if below 12k) (12k)
Ram : 2 gb ddr2 dual (3k)
Hdd : any 250 gb sata 2 (2.3k)
PSU : CM 600 (extreme, as only 1 GPU and modest config) (3.1k)
cabinet : i need one with many fans for cooling.iball gamer? (1.7k)
monitor : dell 20" (12.5k)
ill use my old kb/mouse,APC 500 UPS , Liteon-moserbaer DVD drive as all these are above budget. I wanted PCIe 2.0 mobo below 8k but only AMD based mobos have PCIe 2.0 .will 8800GT perform as good on PCI x16 ?
Reason: Automerged Doublepost
30-06-2008, 02:43 AM
Unmountable Boot Volume
You can get a 9600GSO for just 6K in India. It's much better than an 8800GTS.
Webhosting for Rs12/month!!
http://www.thinkdigit.com/forum/showthread.php?t=74717
http://www.outpowerhosting.com
30-06-2008, 08:24 AM
actually
9600GSO<9600GT<8800GT<8800GTS
and 8800GTS will cost a min of 14~15k.
but 9600GSO is enuf for low~med resolutions.
G3: XPS M1530 |
FZ 16.
30-06-2008, 09:34 AM
I think he mean the previous 8800GTS.
30-06-2008, 10:41 AM
dude , only galaxy 9600GSO with 8 mem chips can be modded to a 8800GTS 512mb and still it doesnt match the 8800GTS .. for 12k budget , 9600GSO is certainly not a card of choice. .stick with 4850 / 8800GT / 9800GTX.
30-06-2008, 10:50 AM
Bond, Desi Bond!
IMHO, AMD 5600+ or Phenom X3 8450 , 780G, 4850 is the best choice for gaming.
780G + 4850 in hybrid crossfire will easily blow away 8800GT or 9800GTX.
30-06-2008, 11:49 AM
Yup, with the 4850 beats 9800GTX even on stock. So itll be hell better with the 780G with upto 30% performance boost on rendering.
G3: XPS M1530 |
FZ 16.
30-06-2008, 12:20 PM
thankx for ur inputs guyz
@desiibond , dOm1naTOr
are u guyz sure AMD(Phenoms) >INTEL (E8400) for gaming? (with ATI 4850 ofcource  )
if so, is it ok if i go with phenom (X4)? as they are quad core....
and plz suggest a nice AMD mobo too..
i can wait till end of july for a new comp ( for ATI 4850 ), but not more..will 4850 be available in July?
Reason: typo
30-06-2008, 03:01 PM
k desii, ill w8 till 4850 is out and get it with tri core phenom....thankx for the linkz, gr8 research
the mobo though might have a problem :
http://www.tomshardware.com/reviews/...t,1785-19.html
refer gerro1977's problem
Pentium 4 2.4 GHz (northwood 478 sockets), VIA p4m266, 768 DDR 133 MHz RAM, Nvidia 5200 FX AGP 256 MB, Local cainet + 350 watt smps, LG 700s Studioworks 17" CRT,80 GB Samsung PATA..need an upgrade ;)
30-06-2008, 03:56 PM
Bond, Desi Bond!
yes. was aware of the problem. I think the latest revision (1.1, i think) of the mobo's from Gigabyte solved the overheating issue by deploying a better heatsink.
30-06-2008, 05:31 PM
01-07-2008, 12:13 AM
@ SKA, AMD 7XX series + phenom + AMD Grfx card makes the spider platform which boosts the rendering performance by 30+ % if HD 3XXX/4XXX cards are used with AMD 7XX chipset.
Wats the Favourite Mathematical Function of DIGIT FORUM ????
Its "A SINE WAVE" constant
Y ??
They Both keep going "UP AND DOWN, UP AND DOWN............" !!!!!!!!
01-07-2008, 08:22 AM
Bond, Desi Bond!
Originally Posted by SKA!
see post #12 in this thread.
Just wait for the 4850 card to come out. There will be Hybrid crossfire tests done by users and you will be able to come to a clear decision.
01-07-2008, 09:18 AM
@harry,desii,
ya i believe waiting and watching will do the trick, make things clear. Visited the amd forums and some guy already has HD 4850 with 780g, but there are some problems. But these can be sorted out through next catalyst drivers, here
in the mean time i can also look out for: GA-MA78GPM-DS2H
