Old 28-06-2008, 04:58 PM   #1 (permalink)
4U
karan4's Avatar
Default Help
When i did a System Health scan (conrol panel -->performane and maintainance-->advanced tools)
The Results gave warnings
a)System is experiencing excessive paging
b) Avg. Disk Queue Length : mean - 8, minimum-2, total-16
My computer config. is
OS Name Microsoft® Windows Vista™ Home Basic
Version 6.0.6000 Build 6000
Other OS Description Not Available
OS Manufacturer Microsoft Corporation
System Name WORKGROUP
System Manufacturer Dell Inc.
System Model Inspiron 1520
System Type X86-based PC
Processor Intel(R) Core(TM)2 Duo CPU T5250 @ 1.50GHz, 1500 Mhz, 2 Core(s), 2 Logical Processor(s)
BIOS Version/Date Dell Inc. A03, 16-08-2007
SMBIOS Version 2.4
Windows Directory C:\Windows
System Directory C:\Windows\system32
Boot Device \Device\HarddiskVolume3
Locale India
Hardware Abstraction Layer Version = "6.0.6000.16407"
User Name WORKGROUP\fanta
Time Zone India Standard Time
Total Physical Memory 1,013.57 MB
Available Physical Memory 141.40 MB
Total Virtual Memory 2.22 GB
Available Virtual Memory 901.13 MB
Page File Space 1.28 GB
Page File C:\pagefile.sys
karan4 is offline
Old 30-06-2008, 03:12 AM   #2 (permalink)
Rebooting
Choto Cheeta's Avatar
Default Re: Help
Move the page file from C drive to any other partition
now this is normal in case of low amount of RAM, as lot of real time application data has to be transfered between the virtual memory and physical memory depending on the apps priority
rebooting
ChotoCheeta.com
Choto Cheeta is offline
