Old 28-06-2008, 12:18 AM   #1 (permalink)
Question Incorrect Latency Shown
I recently brought the three modules of F2-6400CL4S-1GBHK with CL 4-4-3-5 timing but after installing it on my ASUS M2A-VM (AMD 690G Chipset Bios Ver. 1603) board it recognises the timings as 5-5-5-15 i also checked with Everest but it shows the same timing my dealer says that the motherboard is not able to show the timings correctly what shouls i do please guide me to solve the isssue
ranpot is offline
Old 28-06-2008, 04:41 PM   #2 (permalink)
Fast 'N' Furious
topgear's Avatar
Default Re: Incorrect Latency Shown
Go to advanced memory setup of bios or some thing like that. Set the timings manually.
See your mobo's manual for appropriate setings.
ToPsPeEeD = FaSt BuT StEaDy
topgear is offline
Old 30-06-2008, 10:23 PM   #3 (permalink)
Smile Re: Incorrect Latency Shown
thanks dude i did change the latency timings manually through the BIOS it did initialized to 4-4-3-5 but the performance was not as expected. I m not satisfied with Gigabyte GA-MA78GM-S2H Motherboard
ranpot is offline
incorrect MS-DOS function?? rounit Software Q&A 9 12-01-2007 11:52 PM
Processor speed incorrect in laptop abhinavdhall Hardware Q&A 1 27-08-2006 01:07 PM
pls help...incorrect free space reported... karthik316_1999 QnA (read only) 8 03-08-2006 03:21 PM
Help Required in Bit Torrent-Incorrect Peer Info rachitar QnA (read only) 2 07-08-2005 08:13 PM
