Friends my system shutdowns automatically(sometimes). When i opened the cpu case i found that the processor fan is not rotating.
Sometime the fan rotates n stops and again rotate n stop and so on.
The fan is also making some sound like kir kir when i start the system for the first time.I have bought this system(wipro) 8 months ago.
What may be the problem ?
check if the power connectors for ur motherboard are connected properly...also if u can then check if the processor's cooler is seated properly on the processor
Has that CPU fan got a label stuck over the spindle on top? Try carefully peeling back the label and applying a drop of oil (sewing machine oil is best) to the centre spindle, which you'll see under the label.
If the bearing is starting to dry out that'll fix it for a while, but you should really consider another fan if this is the case.
