Old 27-06-2008, 01:19 AM   #1 (permalink)
Default RAM Issue...
I do have a laptop of HP DV1624TN model no. I've 512 MB RAM ( 533 MHz ). I want to install 1 GB. Is it possible to install RAM which has 667 MHz frequency? One stick I already have which is 533 MHz and another one I'm gonna install 1 GB of 667 MHz. Will my laptop give me d performance well or what? What should I do? or shall I go for that one or 533 MHz of 1 GB will be alright?
Please suggest me about this matter.
nkparsana is offline
Old 27-06-2008, 05:57 AM   #2 (permalink)
Violent serenity.
Psychosocial's Avatar
Default Re: RAM Issue...
i dunno if u can upgrade RAM like that in a laptop BUT if u can i suggest u go with matching frequencies that is 533MHz.
Psychosocial is offline
Old 27-06-2008, 12:08 PM   #3 (permalink)
if your motherboard supports 667 DDR then yes u "can" install 667 DDR but it will also run at 533 Mhz. So go for 533 1gb...its better.
Jayanth.M.P is offline
Old 27-06-2008, 02:00 PM   #4 (permalink)
I M A *STAR*
saqib_khan's Avatar
yup, go for 533 MHz 1 GB RAM.
Blogging at:
Technostarry
saqib_khan is offline
Old 27-06-2008, 03:10 PM   #5 (permalink)
check the vendor site whether 667 MHz RAM is supported in your board/ But in anycase you should not use 533 and 667 parallely....that am sure.
Regards,
SKAP
skap is offline
RAM Issue? stylecraze QnA (read only) 4 30-05-2008 11:50 PM
LAN Issue Ethan_Hunt Hardware Q&A 3 12-11-2007 05:55 PM
APC - UPS issue sam9999 Hardware Q&A 8 29-12-2006 12:21 AM
RAM Issue.. dreams Hardware Q&A 13 26-01-2006 08:51 AM
ISO issue taken QnA (read only) 8 16-04-2005 01:39 AM
