Old 26-06-2008, 09:14 PM   #1 (permalink)
M$™ Certified Spammer
entrana's Avatar
Default Clicking sound- important
hey guys ive been hearing this clicking sound like a fan is having an obstacle or something. it was there in my previous pc too before i smashed it and it broke down( literally). yesterday i connected another hard drive and after one day that same sound is coming. but now it comes sometimes i just move the pc a lil. is it possiible that hard drive is faulty. my shop mechie says that. any suggestions guyz
Seagate 500gb 7200RPM l Corsair 2*1GB Ram 800mhz l XFX 8800 GTS 320MB Xtreme 650/ 1500/ 950 l Asus P5N-eSLI l Core 2 Duo e6750 l Coolermaster Extreme Power 600watts SMPS l Microtek 800VA Ups l
entrana is offline
Old 26-06-2008, 09:33 PM   #2 (permalink)
Default Re: Clicking sound- important
A regular clicking sound from a hard disk is very often a sign that it is failing or has developed a bad sector.
A loud continuous rattling sound (like krrrrrrrrr) usually comes from one of the fans. This may be because the blades are touching something (e.g. a wire), OR the bearing has worn out and the fan needs to be replaced out.
Try to describe exactly how the clicking sounds. One word of advice : do not move the CPU while it is turned on. The HD is particularly delicate in this respect. If you must move it, do so very slowly and gently.
pimpom is offline
Old 27-06-2008, 05:55 AM   #3 (permalink)
entrana's Avatar
hmm i dont think its one of the wires i checked
faulty hard drive confirmed i think
entrana is offline
FF clicking problem ! ! ! ax3 QnA (read only) 1 20-01-2007 02:51 PM
Rt. clicking on google ads Simple_Graduate Internet & WWW 2 12-11-2006 10:10 AM
right clicking disabled. SE><IE QnA (read only) 2 09-10-2006 02:42 AM
MOUSE NOT CLICKING IN GTA VC!! sahil_blues Gamerz 1 05-07-2005 11:52 PM
LINUX: NOT CLICKING... sahil_blues Open Source 3 16-02-2005 11:29 PM
