Old 25-06-2008, 10:47 PM   #1 (permalink)
clocker
vivepulicaci23's Avatar
Default PSU help ???
what PSU and how many watts to go for this configuration ??
asus mainboard
core 2 duo(stock cooler)
2x 8800gt in sli
2x 500gb HDD
sony dvd-rw
2x 2gb ram
pls dont tell me to test with some extreme power calculator.
i am confused, as they show strange, and different people suggest different amount of watts.
anyone having this config or running SLI pls let me know how much watts i need ?
thanks!!
vivepulicaci23 is offline
Old 26-06-2008, 01:17 AM   #2 (permalink)
RexRazr's Avatar
Default Re: PSU help ???
cooler master extreme power duo 600w (SLI ready) will do the job but u can go for 650w if u want...
AMD X2 6000+@3.2GHz | XFX nForce 8200 HybridSLI | 4 GB 800 MHz DDR2 | XFX 8800 GT 512 Alpha Dog XXX | Seagate 320 GB Barracuda + Hitachi 250 GB DeskStar | Cooler Master Extreme Power Duo 600 Watts
RexRazr is offline
Old 26-06-2008, 02:19 AM   #3 (permalink)
Go for ocz gamextreme 750watt
that would be the safest option providing you with some future proofing as we all know about the 2xx gtx series
dont go for a high wattage local psu unless you want to get your components fried
Utkarsh2008 is offline
Old 26-06-2008, 10:43 AM   #4 (permalink)
i vote for corsair hx620W although OCZ is also very good. .be cautious since these psu's have power factor correction . they may not be compatible with ur ups. ( u may need a pure sine wave ups ). cooler master real power 650W is also a good choice.
PS
i dont think cooler master extreme power series psu will suffice. if u buy from cooler master , make sure its from the real power series.
sagargv is offline
Old 26-06-2008, 03:37 PM   #5 (permalink)
RexRazr's Avatar
i wasn't talking abt the normal cooler master extreme ones...they wont suffice surely...but the duo series provides SLI and crossfire support and can handle 3 or more SATAII HDDs simultaneously
RexRazr is offline
Old 26-06-2008, 04:16 PM   #6 (permalink)
I thought instead of creating a new thread i'll just ask the question here-
Earlier i was thinking of getting CoolerMaster RP-600-PCAR Extreme Power 600W
but then i thought if i ever wanna get a sli config i'll need better psu
so can
Corsair 620W Power Supply (CMPSU620HX) 6350Rs Corsair 650W Power Supply(CMPSU650TX) 6150Rs handle 2 8800 GT's
i hav a 8800GS right now but i will upgrade my pc after 4 or 5 months.
actually i think i am confused between getting 2 GT's or just a single Ati 4*** series card.
kuki_295 is offline
Old 26-06-2008, 07:16 PM   #7 (permalink)
of course not. . i did not direct my comment to ur post. quite a lot of the cooler master psu's in the market are extreme power ones and i dint want the OP to buy one of those . so i just made that point clear.
sagargv is offline
Old 26-06-2008, 07:47 PM   #8 (permalink)
Alter Bridge=GOD
nish_higher's Avatar
Corsair 620hx ftw.but remember to pay 7-8 for a sine wave ups too.if its out nd budget go with real power pro 550 by cooler master.the 600w psu does not have a 8 pin connector for motherboard and will cause troubles
Apple Macbook Pro 17
nish_higher is offline
