Old 25-06-2008, 01:32 PM   #1 (permalink)
ajnaskhan's Avatar
Thumbs up GIGABYTE GA-MA78GM-S2H - help needed
please anybody help me with the current prices of this mobo and its availability....
comments on this board are also welcomed.....
is anyone out there from kerala then pls specify whether the board is available at ur place and at what price.............
ajnaskhan is offline
Old 25-06-2008, 01:35 PM   #2 (permalink)
Bond, Desi Bond!
desiibond's Avatar
Default Re: GIGABYTE GA-MA78GM-S2H - help needed
you can order online at theitwares.com. i think it costs around 5k
desiibond is offline
Old 25-06-2008, 01:42 PM   #3 (permalink)
Google Bot
Pathik's Avatar
I would say that you rather get the GA-M78SM-S2H. (with Nvidia 8200 IGP) It should be below 4k. The Zotac 8200 is about 3.4k.
Pathik is offline
Old 25-06-2008, 03:47 PM   #4 (permalink)
GIGABYTE GA-MA78GM-S2H has radeon chipset
GIGABYTE GA-M78SM-S2H geforce chipset
can anyone suggest which is good and the price
jith is offline
Old 25-06-2008, 03:50 PM   #5 (permalink)
Bond, Desi Bond!
desiibond's Avatar
I would go with 780G Radeon chipset, buy ATI HD4850 later and use it in hybrid crossfire mode and get most out of the box.
Old 25-06-2008, 05:31 PM   #6 (permalink)
Fast 'N' Furious
topgear's Avatar
It should be Rs. 5450
http://www.theitwares.com/motherboards/motherboards.htm
ToPsPeEeD = FaSt BuT StEaDy
topgear is offline
Old 25-06-2008, 08:12 PM   #7 (permalink)
Attitude matters
Ponmayilal's Avatar
^^ @ desibond ,the Gigabyte website clearly says " * Please use ATI Hybrid CrossFireX certified VGA card (i.e., ATI Radeon HD 2400, 3400 series)."
So the board will not work in crossfire mode with the higher series of ATI cards.Many reviews confirm this.
Ponmayilal is offline
Old 25-06-2008, 10:51 PM   #8 (permalink)
thanks mate,
how is the performance of this board, is it worth buying this board, and hows the graphics performance
jith is offline
Old 26-06-2008, 12:56 AM   #9 (permalink)
I bought it for Rs4850/ a month back.
navis is offline
Old 26-06-2008, 07:59 AM   #10 (permalink)
how is the performance?
jith is offline
Old 26-06-2008, 10:25 AM   #11 (permalink)
I too intersted towords its performance
uday9484 is offline
Old 27-06-2008, 02:52 PM   #12 (permalink)
ajnaskhan's Avatar
Red face Re: GIGABYTE GA-MA78GM-S2H - help needed
GA-MA78GM-S2H
AMD 780G Chipset
  1. Supports AMD Athlon/ Sempron processors
  2. Solid capacitors design in CPU VRM
  3. Dual Channel DDR2 1066 for remarkable system performance
  4. Integrated ATI Radeon HD3200-based graphics (DX10)
  5. Ultimate graphics performance with PCI-E 2.0 x16 interface with ATI Hybrid CrossFireX support
  6. Integrated SATA 3Gb/s with RAID function
  7. Features high speed Gigabit Ethernet and IEEE1394
  8. High quality 106dB SNR ALC889A HD audio
  9. Integrated HDMI/ DVI interface with HDCP
Supports almost all high end AMD Processors available in the market
The onboard Graphics(ATI Radeon HD3200) fetched 2000+ in 3DMARK 2006 benchmarking......
This is ideal for an average gamer...... A dedicated graphics could be plugged in and crossfired with the IGP for better performance, but lacks since support is only for Low-end ATi HD Cards
The onboard Sound is excellent (106dB SNR ALC889A HD audio) with
  1. Support for DTS (dts NEOC)
  2. Support for S/PDIF In/Out
More than that an eSATA port is available on this board....
Supports 16GBs of Memory to the maximum....
Solid Capacitors used on the board ensures better life for the board....
All these for a price tag under 5000/-
BUT SEVERAL REVIEWS OF THIS MOTHER BOARD SHOWS CONCERN OVER HEATING PROBLEMS ON THE INTEGRATED GRAPHICS SOLUTION...... Also it has been heard that gigabyte has rectified this in the newer version of this board rev1.1 to be right...adding additional cooling solution would be another option for that heating woes.......
OVERALL A Good FUTURE AND FEATURE rich board........
A GOOD BUY FOR THE PRICE
Comments and corrections are all welcome...... ahoy....
Old 27-06-2008, 11:53 PM   #13 (permalink)
ith
Just great,onboard graphics can run many recent games with decent FPS.
navis is offline
Old 28-06-2008, 03:02 PM   #14 (permalink)
ankitsagwekar
Posts: n/a
very good mobo run all game like crysis at 800*x600 with athlon x2 5600+
i got this mobo with amd 5600+ for Rs9500
northbridge run normaly @ 84-85c and 106-106c at full load
Old 28-06-2008, 07:25 PM   #15 (permalink)
ajnaskhan's Avatar
Hey dude,.........how much is U satisfied with this board's performance
Old 28-06-2008, 09:23 PM   #16 (permalink)
Had gone with a friend of mine to enquire about this board. But the dealer was keen on pointing out another board from MSI. MSI-K9A2VM-FD / FIH to be precise. So which one is better among these two? MSI-K9A2VM-FD / FIH or GIGABYTE GA-MA78GM-S2H !!
Replies appreciated
cool_techie_tvm is offline
Old 29-06-2008, 03:14 PM   #17 (permalink)
ankitsagwekar
Posts: n/a
i run crysis at midiam setting
if u gi fo msi u don't get esata in some model u also dont get hdmi
i rate this mobo 5/5
it has pci-e 2.0
amd quad core ready ht 3.0
i upgrade amd x4 when price drop
Old 29-06-2008, 03:56 PM   #18 (permalink)
mAYHEM's Avatar
Replies appreciated
Using GA-MA78GM-S2H (rev 1.0),pretty feature rich board when compared to K9A2VM-FD /FIH-S.Get rev 1.1 of the Gigabyte board.
http://www.speedtest.net/result/445135884.png
http://valid.canardpc.com/show_oc.php?id=821188
mAYHEM is offline
Old 29-06-2008, 10:29 PM   #19 (permalink)
Hmm thanks. I will surely recommend the 1.1 version of that Gigabyte MB.
Old 30-06-2008, 09:36 AM   #20 (permalink)
ajnaskhan's Avatar
it has pci-e 2.0
thanx 4 ur rating ankit........
i happy that u r very much satisfied with ur mobo, as i am in for buying one.....
nd how is heat problem dude...........
Old 30-06-2008, 11:29 AM   #21 (permalink)
there is a new version 1.1. i think heat problem is less in 1.1 version. not sure about it
waiting for experts opinion. Will there be any price diff btw 2 version?
jith is offline
Old 01-07-2008, 09:09 AM   #22 (permalink)
mAYHEM's Avatar
Heatsink Difference
Rev 1.0 http://www.gigabyte.com.tw/Products/...ProductID=2758
Rev 1.1 http://www.gigabyte.com.tw/Products/...ProductID=2814
mAYHEM is offline
Old 03-07-2008, 08:35 PM   #23 (permalink)
Fast 'N' Furious
topgear's Avatar
^^ thanks for those links
topgear is offline
Old 11-07-2008, 11:30 AM   #24 (permalink)
ajnaskhan's Avatar
guys finally i got ma hands on the gigabyte GA-MA78GM-S2H.......
Feature rich...............
got 33fps at low settings in CRYSIS DEMO.... without overclocking.....
16 fps at mid settings without overclocking....
mind it this (ATI Radeon 3200) is an onboard chipset............
Sound Quality is Excellent on Realtek HD ALC889A.....
Super Cool with Athlon 4800+ n 2GB ram.........(even though i added two extra fans in the Cabinet)....
not encountered any problems...... almost one week.......
Old 11-07-2008, 11:35 AM   #25 (permalink)
a_k_s_h_a_y's Avatar
^^^^^^ how much did you pay ??
Sony Ericsson Flashing, Modding, Patching, Hacking And More !
http://www.akshayy.com/sonyericsson/
a_k_s_h_a_y is offline
Old 11-07-2008, 08:11 PM   #26 (permalink)
Fast 'N' Furious
topgear's Avatar
@ ajnaskhan
What temps you're getting on idle and at load.
( also post the idle & load durations )
topgear is offline
Old 13-07-2008, 06:42 PM   #27 (permalink)
How about going for 2.2k motherboard + having a GPU(PCI-E) in the range 2.5K ?
gcbeldar is offline
Old 14-07-2008, 09:48 AM   #28 (permalink)
ajnaskhan's Avatar
Smile Re: GIGABYTE GA-MA78GM-S2H - help needed
@ akshay
cost me 4450/- with 4 connectors and 1dvd in the bundle........ sealed
Old 18-07-2008, 11:04 PM   #29 (permalink)
@ akshay
Dude..Did you buy a rev 1.1 or rev 1.0..How'z the NB heat levels?
tmbsundar is offline
Old 23-07-2008, 12:58 PM   #30 (permalink)
@ akshay
Congratulations mate on ur new purchase.I am from Kerala too,Alwaye,to be specific.May I know where ya from?.I wanna upgrade my PC.As the budget is a bit tight,have to rely on onboard graphics.My budget for a new Procy & Mobo is 11K,can't stretch beyond that.
I have got 2 options.1 being and AMD Athlon X2 6000+ with a Gigabyte GA-MA78GM-S2H or an Intel Core 2 Duo E7200 with a pretty decent intel mobo below 5.5 k or thereabout.
When it comes procy i had take E7200 over X2 6000 anyday.But then won't get feature rich mobo like the GA-MA78GM-S2H at such a price.So i am in a dilemma which option do I choose?.
Help me out guys.I would really appreciate.And thanks in Advance
sajudi is offline
Help in assembling GA-MA78GM-S2H amd4800 Hardware Q&A 4 05-07-2008 11:04 PM
GIGABYTE vs ASUS Spat - Apology by GIGABYTE ? shadow2get Random News 2 16-06-2008 04:44 PM
BIOSTAR or GIGABYTE? mandeep_m91 Hardware Q&A 5 29-05-2008 11:35 PM
MSI or Gigabyte ondemandemails Hardware Q&A 7 24-07-2006 09:55 AM
Asus vs Gigabyte sAr QnA (read only) 12 30-10-2004 08:33 PM
