Old 25-06-2008, 11:43 AM   #1 (permalink)
speedyguy's Avatar
Default Harddisk Detected but cant boot
i can see my hdd (not sata i think) 40gb, in bios setup n it is easliy detected at startup as seagate st34XXXXX....but on booting os xp loading screen comes for 2-3sec n system restarts....
i tried reinstalling xp but while partition selection it detects hdd and its size but says "setup cannot access this disk"....n does not display any partition....
wat can b done abt this?
my system is-
p4 1.8ghz @ intel 845GV chipset,
256mb ddr,
ati radeon pro 9200 series 128mb
and...
hdd is connected as primary master...
dvd rom is sec master
cd-rw as sec slave...
ps: i ve tried changing wit ide cables...its alwez same....
Enjoy~!
No Pain...No Gain
speedyguy is offline
Old 25-06-2008, 05:38 PM   #2 (permalink)
Fast 'N' Furious
topgear's Avatar
Default Re: Harddisk Detected but cant boot
Your hdd may be devoloped bad sectors. Last week I the exact same prob with my sata hdd.
If ur hdd is under warranty ry to replace it or else download seatools and fix those bad sectors.
ToPsPeEeD = FaSt BuT StEaDy
topgear is offline
Old 26-06-2008, 12:41 AM   #3 (permalink)
At Hell's Disq
hellgate's Avatar
del all hdd partitions and then create new partitions but with diff capacities than b4.then try installing XP in a diff partition.
hellgate is offline
Old 26-06-2008, 12:58 AM   #4 (permalink)
crazydevil's Avatar
i too had same problem last month...
so i connected my hdd as secondary hdd in my friends pc and ran DSKCHK all the bad sectors are repaired ..
and now my sys is working perfectly
crazydevil is offline
Old 26-06-2008, 08:39 AM   #5 (permalink)
speedyguy's Avatar
n wat abt datas...can they b saved?
Enjoy~!
No Pain...No Gain
Old 26-06-2008, 09:14 AM   #6 (permalink)
Limited data recovery is possible from bad sectors.
Regards,
SKAP
skap is offline
Old 26-06-2008, 01:26 PM   #7 (permalink)
crazydevil's Avatar
yes ..there will be no change in data
Old 26-06-2008, 04:17 PM   #8 (permalink)
ax3
Cool as a CUCUMBAR ! ! !
ax3's Avatar
visit ur frd & try hdd on his pc .......
... W H O T ...
ax3 is offline
Old 27-06-2008, 09:44 AM   #9 (permalink)
dhanusaud's Avatar
must have bad sectors in it..try formatting & reinstalling OS in other partition you have. Also it may be due to bad memory module & loose data cables...check it on spot.
my blog http://www.dhsthemes.blogspot.com
themes for symbian phones
dhanusaud is offline
Old 27-06-2008, 02:15 PM   #10 (permalink)
IM AS MAD AS HELL!!
max_demon's Avatar
it is the same prob as mine i got in a new hdd , (not even 1 month) i tried resetting the Partition table and MBR , i even tried repairing using chkdsk command . still no help ..
it is given 4 replacement now
When someone dies in the grip of a powerful rage... a curse is born.
Kayako Saeki: Croakkkkkkkkkkkkkkkkkkkkk!
max_demon is offline
Old 27-06-2008, 02:58 PM   #11 (permalink)
when you get a replacement, check it in the vendor's site when it is sold out. some dealers hand over old hdd they have.
Regards,
SKAP
skap is offline
harddisk hanging during boot(more info inside) casual_gamer Hardware Q&A 1 07-01-2008 08:44 PM
Harddisk won't boot FŘēēβǿǿtēŘ Software Q&A 2 08-12-2006 03:13 AM
dual boot from dual harddisk?? spyder Software Q&A 10 09-04-2006 10:05 PM
harddisk not detected nach p QnA (read only) 11 22-01-2006 10:44 PM
External Harddisk not detected Gaurav Hardware Q&A 4 28-11-2005 12:21 PM
