Old 24-06-2008, 10:14 PM   #1 (permalink)
Oxygen !!
avi1708's Avatar
Default What's the difference between woofer, sub-woofer & dual-woofer ??
avi1708 is offline
Old 24-06-2008, 10:18 PM   #2 (permalink)
gopz's Avatar
Default Re: What's the difference between woofer, sub-woofer & dual-woofer ??
Woofer handles the midrange frequencies (Voice)
Sub woofer handles low range Bass (like 60Hz and below)
Dual woofer is the same as above but with left and right channels separate.
and...Tweeter handles all high range frequencies (Treble)
gopz is offline
Old 25-06-2008, 08:49 PM   #3 (permalink)
mayanksharma's Avatar
Subwoofers:
It is an audio speaker which is specially designed to reproduce low frequency sound, generally from 200 Hz down to around 20 Hz. Two types of Subwoofers: Active or Powered Subwoofers are driven by their own dedicated amplifier while Passive Subwoofers must be driven by the same amplifier that powers the other speakers in the system.
Additional subwoofer design variations include Front-firing , and Down-firing, and the use of Ports or Passive Radiators!
Woofer: A typical universal term for a loudspeaker which reproduces "Bass" effect (/wwooff/)!
Woofer is the term commonly used for a loudspeaker driver designed to produce low frequency sounds, typically from around 40 hertz up to about a kilohertz or higher.
Dual SubWoofers:
See, A Dual Subwoofer is nothing but one speaker system featuring and two 7-21 inch woofers with 2.5-inch and high temperature voice coils and a better 2-way passive bass reflex design.
Remember, a typical dual subwoofer packs more punch, weight, power and response! Not to mention the massive enclosures with insane dimensions!!
Ok, remember all those Bryan Adam/Pink Floyd/Sting/MJ's concerts?? Yeah, all the credit to those massive sound reproductions goes to these things.
So, now you know.
mayanksharma is offline
Old 25-06-2008, 10:55 PM   #4 (permalink)
moshel's Avatar
^^^Thanks
moshel is offline
Old 25-06-2008, 11:40 PM   #5 (permalink)
Oxygen !!
avi1708's Avatar
wow!
avi1708 is offline
Suggest Woofer kirandnair Hardware Q&A 2 26-05-2008 10:08 AM
Dedicated tweeter and dual woofer in earphones!!!! desiibond Mobiles and Tablets 5 26-03-2008 07:23 PM
Sub-Woofer placement near CPU (not shielded) thrash_metal CPU / Motherboards 3 12-10-2006 05:58 PM
woofer neyo Hardware Q&A 6 02-10-2006 12:40 AM
Woofer Demo Tracks club_pranay QnA (read only) 7 22-04-2005 05:54 PM
