| Forum |
#1 (permalink) |
champ_rock
I have a ASUS laptop and its DVD reader has suddenly started giving problems . Whenever I insert any DVD or CD, it tries to read it (makes some humming noice for a few seconds) and then stops. The cd/dvd is not being detected in both Windows as well as Linux . So i dont think that ir can be a software issue. Earlier, it used to give this same problem with only a few of my DVDs . Scratches are not a problem as i am using fairly new DVDs/Cds. Any solutions?
------------- Registered Linux user number 400618 |
#2 (permalink) |
u can try cleaning the lens of ur DVD-ROM (is it?) with a good lens-cleaner and see if it works...
otherwise...service-centre
AMD X2 6000+@3.2GHz | XFX nForce 8200 HybridSLI | 4 GB 800 MHz DDR2 | XFX 8800 GT 512 Alpha Dog XXX | Seagate 320 GB Barracuda + Hitachi 250 GB DeskStar | Cooler Master Extreme Power Duo 600 Watts |
#3 (permalink) |
champ_rock
I already have cleaned the lens. And there is no service center for ASUS Laptops in Delhi
And one more thing, I am planning to upgrade my RAM. Can you please tell me, how can I know which RAM do I have? DDR1 or DDR2? Also, will my motherboard support 1.5GB ram?
#4 (permalink) |
Champ tumhare Dant to Motion jaise chamak rahe hain. Ok
1. for Dvd reader you must change its lense. lense seems to be currupted here. if no service centre then many other computer hardware repairing shops are available. 2. to know about each smallest part of your system download, install and run the tiny software: Everest Home Edition. Just google it. good by. |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| adobe reader installation problem... | vavinashraju | Software Q&A | 5 | 04-08-2007 10:12 AM |
| ebook reader software like microsoft reader.. | Manshahia | Software Q&A | 3 | 22-05-2007 01:46 PM |
| Card Reader Problem in XP | premsharma | Hardware Q&A | 16 | 08-03-2007 10:23 PM |
| facing some problem in using card reader | jacques | Buying Advice | 2 | 10-02-2006 06:40 PM |
| card reader problem | gdatuk | Hardware Q&A | 1 | 06-02-2006 03:55 PM |
