| Forum |
#1 (permalink) |
9437077259
I have a P4 with 512 MB DDR RAM. As to what I remember, I took a 400 MHz. RAM but when I check the same with CPUZ, it shows both 166 MHz & 200 MHz. Even if I add it, it comes to 366 MHz. How is it actually calculated? ![]() Thank you.
Win 7 Ultimate Abit IP35-E Mobo,C2Q 6600,4GB DDR2 RAM,XFX 8600GT 256MB DDR3 Gfx ,Seagate 1TB HDD,Sony DVD RW,500w SMPS,19" Viewsonic VX922 TFT,Logtech G5 Mouse,Altec Lancing 2:1 Speakers. |
#3 (permalink) |
Internal clock in DDR2 will be half of what the actual transfer rate is ... Coz in DDR2 there will be two data transfers in every cycle
But in your screenshot it is showing DDR and not DDR 2 ... So it may be 200 Mhz itself .. If you want accurate value check in BIOS
I am Back.... Last edited by Beta Waves; 24-06-2008 at 07:05 PM. Reason: Automerged Doublepost |
#4 (permalink) |
9437077259
DDR doesnt come in 200 MHz. Its comes in 266, 366 & 400 MHz, if I am not wrong.
#5 (permalink) | ||
Wire muncher!
DDR = Double Data Rate = 2 x Rated Speed, hence DDR400 = 2 x 200mhz. Plus, do you see the rating there? PC3200? The 3200 represents the bandwidth in MB/s. How do you calculate this? DDR Ram has a 64bit wide channel. BW of DDR RAM = 2 x Rated speed x 64bits x 8bits/byte Hence 2 x 200mhz x 64bits x 8bits/byte = 3200 = PC3200. The highest DDR ever produced was DDR400 which has a bandwidth of PC3200. Since your module has the exact same bandwidth (PC3200), your RAM is DDR400. There is ABSOLUTELY no doubt about it. Rest assured
"The true measure of a man is how he treats someone who can do him absolutely no good." http://phoenix-ani.blogspot.com |
#6 (permalink) |
Sorry I made a mistake in my previous post ...
DDR RAM internal clock wil be half the rated speed i.e yours is DDR 400 that means internal clock is 200 MHz .. so it is showing correct .. DDR2 RAM internal clock will be 1/4 the rated speed ..
I am Back.... |
#7 (permalink) |
9437077259
Thanks a lot guys! Confusion cleared...
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| Tokyo boffins crack internet speed record - reached 7.67Gbps speed! | Kiran.dks | Technology News | 35 | 19-10-2007 01:16 AM |
| utorrent prob, upload speed is higher than download speed | daemon | Internet & WWW | 2 | 17-07-2007 03:05 PM |
| whats this? | mayneu | Software Q&A | 2 | 29-12-2006 07:06 PM |
| Whats VAS ?? | Dipen01 | Mobiles and Tablets | 11 | 11-10-2006 08:09 PM |
| Whats 3G and 4G? | The Incredible | Mobiles and Tablets | 5 | 24-09-2005 06:49 PM |
