i have decided on buying a external hdd as my 40 gb internal disk is of no use nowadays with so many movies to dow..er buy.
first i thought of buying 2.5" ones but found 500 gb ones to be too expensive. so have decided to buy 3.5" ones i scoured lamington and found price in range of 4200-4800 rs.
now first of tell me if i will have any particular problems with 3.5" ones i plan to caryy it in local once a month apart frm that it will eb at home only.
and if 3.5" ones are ok for my use then suggest a product with price and any other useful info u might have.
thx.
