Hi guys,
I wanted to back up the data in my system so i bought some
DVD+R dvds. As I had no idea what is the difference between
DVD+R and
DVD-R i asked the store guy abt it and he said like it doesn't matter which one u take. Then i took my friend's
Dell Inspiron laptop with a
DVD+-RW drive and
Vista OS to write the data. Now the freaking problem starts. As we all know
Nero doesn't work on Vista. So i installed
Nero Lite a lighter version of Nero which works on Vista. As i started writing with the Nero Lite each time it failed popping a
"Power Calibration Error" msg. Then i tried the default s/w in Vista but the same result followed without the error msg (i think it was Nero specific). Then i tried with a DVD-R and it wrote without any problem. Now here i am not getting wht is this problem with DVD+R. I searched 4 the error and tried some of the solutions but nothing seems to work. Now i know i can very well xchange the DVD+R with DVD-R and go on with the back up then wht is the use of having a DVD+-RW drive which only writes DVD-R. I don't know whether its a s/w or h/w problem still i am posting it in the h/w section. Guys plz hlp me with this.
