hi guys. I am facing a strange problem with my dvd writer. It is a Sony DRU-820A one & half years old. I use nero 6 to burn dvds. nero shows a pop-up that burn process is completed successfully. Then when I enter the DVD in the tray , I can see all the files but cannot run anything. Whenever I try to run anything from the dvd , system hangs. Only ejecting the tray solves the matter. Is it time to send it to service centre or buy a new 1? Plesae help me in this matter.
My system config : P4 2.8Ghz, D945GNT mb,2*512 ddr2 533mhz ram,160gb hd(hardly 10gb empty space only) running Win XP SP2.
Thank You
Soumya
