Old 22-06-2008, 11:51 AM   #1 (permalink)
Default Is the Antec SP400 enough for my rig?
I have a PC with the following config.
Intel C2D 4500 2.2GHz
Abit IP 35 E
2GB Transcend DDR2 800MHz(1GBx2)
160GB SEAGATE SATA HDD
Galaxy 8600GT 256MB DDR3
DELL SE198 WFP 19" LCD
SONY 820A DVD Writter
SAMSUNG DVD Drive
FRONTECH TV Tuner Card
ATP 3 2:1 Speakers
Saitek Eclipse II Keyboard
400 watts Antec SP PSU(12V R1=15a, 12V R2=14a)
SLK 3000B Cabinet
650VA APC UPS
120mm LED FANS - 3
80mm LED FAN - 1
4" Dual BLUE CCFL
can my Antec SP400 PSU handle my RIG smoothly?
dare devil is offline
Old 22-06-2008, 12:29 PM   #2 (permalink)
RexRazr's Avatar
Default Re: Is the Antec SP400 enough for my rig?
it should be fine i think...go ahead n check it here
http://www.extreme.outervision.com/p...ulatorlite.jsp
AMD X2 6000+@3.2GHz | XFX nForce 8200 HybridSLI | 4 GB 800 MHz DDR2 | XFX 8800 GT 512 Alpha Dog XXX | Seagate 320 GB Barracuda + Hitachi 250 GB DeskStar | Cooler Master Extreme Power Duo 600 Watts
RexRazr is offline
Old 22-06-2008, 01:20 PM   #3 (permalink)
The Tech Enthusiast
your motherboard is one which requires quite some power. not to mention your graphics card. you should opt for something over 450W. consider VIP 500W PSU which comes for around 2.4k
piyush2202 is offline
Old 22-06-2008, 08:15 PM   #4 (permalink)
Piyush:My GPU 8600GT
The PSU upgrade is necessary or not?
Old 22-06-2008, 11:11 PM   #5 (permalink)
RexRazr's Avatar
u don't need to upgrade PSU for ur 8600GT...however if u want to OC (CPU or GPU)...then it's a different story...u can go for better PSUs to be futureproof anyway
RexRazr is offline
Old 23-06-2008, 02:43 AM   #6 (permalink)
johnjjx's Avatar
more than enough. 15A+14A is enough juice to drive ur components.....
e8400 / abit ip35-E / gskill 4gb / mx5021 + audigy 2zs / Visiontek 4870 / corsair vx450 / Dell E198wfp
johnjjx is offline
Old 23-06-2008, 08:40 AM   #7 (permalink)
When the LCD Monitor (DVI Connection)is switch on,the brightness of the LED fans in the Cabby goes down.
Also the voltage ratings of the PSU are:
+3.3V -3.22v
+5V -3.74v
+12V -13.49v
CPU Voltage -1.23v(voltage ratings from PC wizard 2008)
1)What is the reason for the LED fans Brightness goes down?
2)Are the Voltage ratings normal?
3)Is there any problem in my Antec SP400w?
Old 23-06-2008, 03:55 PM   #8 (permalink)
Roadripper's Avatar
C if u get 25+ amps on 12 v lines its not gonna coz any harm ... how much amps does ur psu give .. i think its 20+ let me knw...
Roadripper is offline
Old 23-06-2008, 06:13 PM   #9 (permalink)
15+14=29a
Old 24-06-2008, 07:54 PM   #10 (permalink)
The Tech Enthusiast
Sorry i missed that bit. I think your current one should be fine. As long as your not into hardcore overclocking, it should just do fine.
antec power supply yogi7272 Hardware Q&A 13 01-08-2006 07:47 PM
Looking for Thermaltake,Antec PSU's snake Hardware Q&A 18 02-06-2006 12:15 PM
Antec Sux !!! mohit QnA (read only) 4 08-05-2005 03:27 PM
