Old 22-06-2008, 12:14 AM   #1 (permalink)
Wise Old Crow
blueshift's Avatar
Default Monitor display goes blank
My uncle recently purchased a computer. Its config is given below:
C2D 2.4GHz, Intel G33 original motherboard, 1x2GB RAM 800MHz(Transcend), 400W SMPS, 19" LCD(LG).
Last few days, it is behaving weird. The display automatically goes blank(not power-off) after the boot. After power-off the monitor and then ON it, it goes blank after few seconds.
I checked the RAM and replaced it in other slot? I checked for cable connections..Still the problem persists.
One more thing..I get a shock when I touch the back panel of the cabinet..So its possibly not earthed properly. Could that be a problem?
http://twitter.com/blueshift155
blueshift is offline
Old 22-06-2008, 01:52 AM   #2 (permalink)
smile's Avatar
Wink Re: Monitor display goes blank
If u have graphics card installed , then try to remove and put it again correctly. Yes u will get a shock if ur earthing is bad , Call an electrician to check the earthing
SR
smile is offline
Old 22-06-2008, 09:18 AM   #3 (permalink)
Wise Old Crow
blueshift's Avatar
Default Re: Monitor display goes blank
there's no graphic card.
I need to know whether bad earthing can cause monitor to go blank..or is their any other problem.
Please reply.
Old 22-06-2008, 10:50 AM   #4 (permalink)
prasad_den's Avatar
Not sure if bad earthing can cause monitor blanks, but it definitely decreases the life span of all the electronic components drastically. Get that checked irrespective of the monitor problem..
For the monitor, try checking it in one of your friends' system.. chances are, you'll know if the problem is inherent in the monitor, or if it is due to the CPU or earthing issue.
prasad_den is offline
Monitor display goes blank midhunmon Hardware Q&A 2 01-05-2008 03:10 PM
Display going blank after the xp loading screen soumya Hardware Q&A 5 26-02-2007 04:24 PM
my monitor is blank!! help anzaan Software Q&A 5 01-12-2006 03:32 PM
Monitor went blank (Urgent) rahul_2350 Networking 5 02-08-2005 09:07 AM
how to attach 6 devices ? display going blank vaishali Networking 15 19-04-2005 02:40 PM
