Yes it's possible most LCD TVs have D-SUB/VGA and DVI connectivity options.
Just set the resolution to 1366*768 (your graphics driver should do this by default for you ) and your LCD TV will be up and running.
Note - I have mentioned the resolution as 1366*768 as this is the most common resolution prevalent among LCD TVs nowadays unless you get a LCD TV with a screen size below 26 inches or the ones which support 1080P.
Computers are like air conditioners. They work fine until you start opening windows.
