Old 20-06-2008, 07:56 PM   #1 (permalink)
Stuck
Question BIOS Auto Resetting !!
Hi !
I have a problem with my system. Every time I start my computer the BIOS settings are automatically resetted, and the computer stops in bootup. Then I have to go to the BIOS settings and then after again booting it works normally.
I changed the CMOS battery since it supplies current to the BIOS chip. It worked fine for one day and then it again started happening. Then I checked the CMOS jumpers and they are in the propre prosition too. I can't think of anything now.
My motherboard is a Mercury 945GZD running two HDD's, 512 mb DDR2 ram and a DVD-RW drive with C2D E4400.
Please give me some really decent solutions.
Vivek.28 is offline
Old 20-06-2008, 09:35 PM   #2 (permalink)
Jai Suresh
lywyre's Avatar
Default Re: BIOS Auto Resetting !!
Try changing you battery again. Check the manufactured of the same before you buy. If it had been too long on the shelf, then its as good as a dead battery.
lywyre is offline
help:resetting bios password VINSTAR Software Q&A 9 15-05-2008 09:56 PM
Discussing Resetting of password..is it OK ? Thor Software Q&A 4 27-09-2006 07:27 PM
Password Resetting Disk Kalyana Software Q&A 1 21-09-2006 09:44 AM
Resetting A Password (a.k.a. change the admin's password) wolvrine Tutorials 25 08-09-2006 02:57 PM
Auto Cad adi87 QnA (read only) 2 24-06-2006 06:05 PM
