Old 20-06-2008, 10:41 AM   #1 (permalink)
Default RAM
is the performance and fps better when having 2gb ram or 4gb ram.
i have 2x1gb transcend ddr2 800mhz ram and
2x1gb samsung ddr2 667mhz ram
should i use them combinedly or not.also is the performance difference negligble and not worth the trouble of dealing with 64-bit OS's issues.
adithya217 is offline
Old 20-06-2008, 11:41 AM   #2 (permalink)
channabasanna's Avatar
Default Re: RAM
As far as i know we cannot use RAM with different frequencies together..
C2Q Q6600 G0|ASUS Maximus Formula|XMS2 1GB x2|CM extreme Power 600W|CM Elite 332|WD 320GB HDD|Seagate 80GB HDD|SONY DVD+RW|Viewsonic VA1912wb 19"|XFX 7600GS|OCZ Vendetta 2|HP dv2601tx|Nokia N73 ME
channabasanna is offline
Old 20-06-2008, 04:30 PM   #3 (permalink)
Beta Waves's Avatar
Default Re: RAM
I think you can use .. if you have four slots see that there will be two each which will be in the same colour .. so insert your two 800 Mhz RAM sticks in the same coloured slot and the other two in the second coloured slot
I am Back....
Beta Waves is offline
Old 23-06-2008, 12:42 PM   #4 (permalink)
ECE0105's Avatar
Default Re: RAM
Yep, Read the slots as A,B,C,D from the CPU Side to the edge of the Mobo.
The 800MHz RAM Should be inserted in A and C and the 667 MHz should be in the B & D Slots. This will ensure that the RAM Runs in Dual Channel Mode.
Some of the happiest people in the world do NOT have Everything... They just make the Best of Everything life brings their way... So, Stay HaPpY.... Smile Always.... :-)
ECE0105 is offline
Old 23-06-2008, 02:30 PM   #5 (permalink)
RexRazr's Avatar
Default Re: RAM
tho i think u better stay off from using RAM sticks together that have different frequencies...just to avoid certain issues
AMD X2 6000+@3.2GHz | XFX nForce 8200 HybridSLI | 4 GB 800 MHz DDR2 | XFX 8800 GT 512 Alpha Dog XXX | Seagate 320 GB Barracuda + Hitachi 250 GB DeskStar | Cooler Master Extreme Power Duo 600 Watts
RexRazr is offline
Old 23-06-2008, 03:48 PM   #6 (permalink)
Beta Waves's Avatar
Default Re: RAM
May be different motherboards have differnet order so just follow the colour code same type of RAM modules in same colour slots ....
I am Back....
Old 23-06-2008, 03:53 PM   #7 (permalink)
Roadripper's Avatar
Default Re: RAM
B it ll run at the lower frequency only .. ie 3.2gb in 32 bit @ 667 Mhz...
Roadripper is offline
Old 23-06-2008, 04:00 PM   #8 (permalink)
Beta Waves's Avatar
Default Re: RAM
May be it runs at lower Frequency itself ... that i am not sure ... but it is 64bit wide buddy not 32 bit
I am Back....
Old 23-06-2008, 04:03 PM   #9 (permalink)
Roadripper's Avatar
Default Re: RAM
^^ i said for 32 bit OS systems u can utilise onyl 3.2gb of ram whre as in 64bit u can utilise full 4gb... its 2^32 and 2^64 transistors ..
Old 23-06-2008, 04:15 PM   #10 (permalink)
Beta Waves's Avatar
Default Re: RAM
No no you got me wrong .. I think i got you wrong i was talking about the data bus width not about the address bus
And there is slight mistake in your calculations .. When you say 32 bit processor it means it has 32 bit address lines ..so 2^32 combination...so actually the processor can access 2^32 memory locations. i.e calculate 2^32 and divide it by 1024 thrice that is the amount of RAM in GB the processor can utilize ...that turns out to be 4 so a 32 bit proc can access 4GB of RAM
And if you do 2^64 and divide it by 1024 thrice you will get a very huge number in the order of power 10 !!! i don think anyone will be using 1X10^10 GB of RAM ...lol
I am Back....
Old 23-06-2008, 11:37 PM   #11 (permalink)
Roadripper's Avatar
Default Re: RAM
yeah u took me as data bus width and i took as address lines ..No man i hav personally checked on ma frns pc wit 4gb of ram on 32bit OS its 3.2gb nt complete 4gb ...logically ur correct....
