Old 20-06-2008, 12:40 AM   #1 (permalink)
Default Advice !!!!!
Hi guys i am new here i want you advice on the following config.
I will be assembling a new PC...
MB - ABit IP35-E - Rs. 5400/-
CPU - Core 2 Duo E8200 - Rs. 7950/-
RAM - G-Skill - F2-6400CL5S-1GBNQ (1GB) - Rs. 1400/-
GPU - eVGA 9600 GT KO Rs. 9350/-
Is it good....
Other components i have selected like cabinet, HDD etc
I will be buying it from I T Wares, can anyone express his opinion on this dealer.
this is my first online purchase.
Thanks.
dattu1984 is offline
Old 20-06-2008, 10:56 AM   #2 (permalink)
Bond, Desi Bond!
desiibond's Avatar
Default Re: Advice !!!!!
if you can put more money, get IP35-Pro or MSI P7N SLI Platinum.
desiibond is offline
Old 20-06-2008, 10:59 AM   #3 (permalink)
Alter Bridge=GOD
nish_higher's Avatar
^ +1 for P7N SLi plt
also get 2gb ram .1gb will be a bottleneck even if its a gskill.
Rahul (theitwares) is a great dealer.u should not have any problems with him.
Apple Macbook Pro 17 :cool:
nish_higher is offline
Old 20-06-2008, 11:12 AM   #4 (permalink)
Alpha Geek Banned
bikdel's Avatar
Mobo is okay, ram is less. If u can, then wait for 2-3 weeks and who knows you may get 2x powerful graphics card in that budget!
I'm not a GEEk, i still use Windows!
bikdel is offline
I want ur advice rajputsanju Mobiles and Tablets 5 30-05-2007 09:44 PM
Need Advice william QnA (read only) 5 01-04-2006 10:42 PM
An Advice maximus QnA (read only) 5 22-04-2005 11:22 AM
ADVICE ME PLZ.......... hareesh QnA (read only) 15 24-02-2005 07:01 PM
Your advice-reg. kumarn_2004 QnA (read only) 3 05-02-2005 05:19 PM
