Old 19-06-2008, 06:17 PM   #1 (permalink)
Spiff's Avatar
Default Biostar M6TWL motherboard (Intel 810E)
Currerntly i m having on my old pc:
P III - 866 MHz.
64 MB x 2 SDRAM
20 GB HD
Now i want to upgrade it to 512 MB SDRAM. nd Hard disk n cpu too...
nw pls tel me wat can i gt for d same motherboard... i plan to use linux(ubuntu) on it...
Spiff is offline
Old 20-06-2008, 10:38 AM   #2 (permalink)
Bond, Desi Bond!
desiibond's Avatar
Default Re: Biostar M6TWL motherboard (Intel 810E)
throw that mobo away and get this if you are on a strict budget:
1) Intel Dual core E2180 : Rs.3k
2) Intel DG31PR : Rs.3.5k
3) 1gig DDR2 800 : Rs.1.1k
4) 160gig sata2 hdd : Rs.2k
5) 250gig sata2 hdd: Rs.2.6k
desiibond is offline
Old 20-06-2008, 12:10 PM   #3 (permalink)
Spiff's Avatar
Thanks for the new config.....
bt i already hav a new pc.... bt just wantd to upgrade d ol one to test my hands on.....
i m just learning bout hardware dese days.....
Thank u desiibond!
Spiff is offline
Old 20-06-2008, 12:23 PM   #4 (permalink)
Bond, Desi Bond!
desiibond's Avatar
ah. okay.
IN that case, get a 512Mb SD RAM stick for around Rs.700
It's not possible to get new Pentium 3 CPU these days. Post for a second hand CPU request at the Bazaar section.
you can get a 160gid PATA HDD for 2k these days.
810E chipset should support any P3 processor (P3 maxes out at 1.2Ghz)
Old 20-06-2008, 06:44 PM   #5 (permalink)
Spiff's Avatar
Thanks!
will 2X 256 MB provide better performance.
Spiff is offline
Help- Gaming in intel 810e ganesh_2218 Reviews 11 22-05-2009 09:44 AM
Biostar TP35D2-A7 + Intel E2160 overclocking axxo Overclocking 100 04-06-2008 03:00 PM
Best Intel Motherboard Udaya Maurya CPU / Motherboards 1 11-09-2007 12:09 PM
sound channel supported by intel 810e supersaiyan Hardware Q&A 5 30-06-2006 10:59 AM
