Old 19-06-2008, 12:46 PM   #1 (permalink)
anarchy0x's Avatar
Default dvd writer not writing dvds
hi, i know som1 has already reported a similar problem but mine isa bit different, not only i am unable to write dvds but also rewritable dvds, i have tried 5 upto now & all of them have gone bad. & my dvd writer is out of warranty.. any ideas? n i have tried nero,other burning softwares as well... help will be appreciarted.. i dont have any friend who stays closeby so that i can try my burner on his but i ll try if i can..
anarchy0x is offline
Old 19-06-2008, 01:57 PM   #2 (permalink)
New
New's Avatar
Default Re: dvd writer not writing dvds
Which is your DVD writer? I mean which brand?
New is offline
Old 19-06-2008, 08:18 PM   #3 (permalink)
anarchy0x's Avatar
the brand is samsung.. & it doesnt have any problem reading dvds
Old 19-06-2008, 08:46 PM   #4 (permalink)
Please clarify problem is only for writing,or for playing also.Possible cause may be a dirty lens of the dvd writer.Try a lens cleaning cd.Or your DVD writing software may be corrupted.Try reinstalling Nero or other software you are using.Or one more possible cause may be a faulty datacable,I.e the cable that connect dvd writer to mother board.Check data cable as well.try these things.your problem may be solved.If not contact service center of the brand u r using.
gunda_26 is offline
Old 19-06-2008, 09:08 PM   #5 (permalink)
Point Blanc
what error you get while you try to burn, can you explain it, I mean is it starting to burn and completes to fail or is it failing to initate right from beginning
acewin is offline
Old 19-06-2008, 09:18 PM   #6 (permalink)
it is not data cable.it is ide cable.use 80 conductor ide caBLE.
techtricks.co.in
portforwarding
xp-vista crossover connection
installing xp on vista notebooks
sreenidhi88 is offline
Old 19-06-2008, 10:26 PM   #7 (permalink)
bajaj151's Avatar
Similar problem with my dvd writer....writing dvd but not cd..
Phenom x6 1055T 3.75 GHz | MSI 890GXM G65 | Corsair XMS3 2*4GB 1600mhz | BenQ E2200HD | Xbox 360 Controller | Seagate 2TB | CM HAF 922 | Corsair VX 550 | Logitech MX 518 | Logitech Wireless Keyboard | Sapphire 7850 OC
bajaj151 is online now
Old 19-06-2008, 10:47 PM   #8 (permalink)
TheSaint
NucleusKore's Avatar
Did you all try with lower speeds? 4x?
http://www.neville.in
http://www.linuxrocks.in
"The Future Is Open"
NucleusKore is offline
Old 20-06-2008, 03:12 AM   #9 (permalink)
anarchy0x's Avatar
it can read data perfectly but cant write... n i tried more than 1 dvd burning software but the problem is still there..
error .. i get an error saying burn process failed or even if it gets burnt the last thing which was burnt doesnt work . if u know what i mean
Old 20-06-2008, 01:20 PM   #10 (permalink)
Point Blanc
have you tried resetting DMA, if not try it. I think its a common problem in DVD burners and you need to keep thisDMA reset
after this step try burning your dvd
acewin is offline
DVD Writer not writing DVD writable walky Hardware Q&A 8 19-06-2008 07:35 AM
DVD writer not writing ritish Hardware Q&A 4 27-12-2007 10:33 AM
LG DVD Writer Cant read Cds but Reads All DVDS... hmmmmmmmmmmmmm QnA (read only) 4 07-10-2007 08:12 AM
DVD Writer not writing DVDs, Please help Anurag A Hardware Q&A 2 01-09-2006 06:29 PM
Best software for conversion and writing DVDs? 144 Software Q&A 5 15-11-2005 08:35 PM
