Old 18-06-2008, 09:46 PM   #1 (permalink)
Default Help reqd for upgrading to SLI
My current config...
E6850 Core 2 Duo 3 GHz
XFX 680i LT SLI Board
Sparkle GeForce 8800GT 512 MB graphics
2 Gigs Transcend 800mhz DDR3
320 GB WD SATA HDD
500w Zebronics Platinum power
Planning to go SLI soon...need advice...
All advice is welcome but some specific Qs are as under...
1. Can my Second Graphics card be any SLI card or does it have to be another 8800GT ie can
it be a 9600 GT for example? Does it have to be Sparkle, or can I use an XFX card, or any
other brand of card for that matter?
2. power...more required? Any suggestions?
fieldgunner is offline
Old 18-06-2008, 10:45 PM   #2 (permalink)
Alter Bridge=GOD
nish_higher's Avatar
Default Re: Help reqd for upgrading to SLI
1.tin same cards are required for sli.
2.any sli certified psu will work.if ur's is,no need to upgrade
Apple Macbook Pro 17 :cool:
nish_higher is offline
Old 19-06-2008, 03:01 PM   #3 (permalink)
same chipset? or even same brand?
Old 19-06-2008, 03:10 PM   #4 (permalink)
Alter Bridge=GOD
same clocks.better to get same model
Old 19-06-2008, 03:35 PM   #5 (permalink)
I think you will need a PSU Upgrade. chek out SLIZone for recommended PSUs for 2 8800GTs. Also, they both need to be 8800GTs, with same clocks and Memory frequencies, so best to get the same card.
Kush6 is offline
guidance reqd:Bad DDR RAM longlife Hardware Q&A 3 24-04-2008 07:38 AM
SE W550i help reqd. panacea_amc Mobiles and Tablets 3 14-04-2008 02:55 PM
Gprs help reqd panacea_amc Mobiles and Tablets 7 30-08-2007 10:41 AM
WinXP SP2. How much RAM reqd ? anandk Software Q&A 27 20-05-2005 05:29 PM
help reqd connecttovijay QnA (read only) 3 18-10-2004 01:25 AM
