Old 18-06-2008, 03:50 PM   #1 (permalink)
Climbing..........
slimTech's Avatar
Question Pen Drive capacity has decreased by 480MB
Hi
I have got a 2GB My Flash pen drive from A-Data. It came bundled with usb utility that helped create partition as public and secured (one for both). At this time the capacity was 1.88GB. I created a secured parition of 250MB and rest for public. It worked well for two or three months until I got both the partitions removed away. To access the device, I had to format and it only showed the capacity that was for public partition before i.e. 1.65GB (I tried of course with windows formatter as well as with device utility software). No matter, it was ok with that. But few days back once again the capacity has been decreased to 1.41GB and it often gives error while carrying data.
I have also tried with paritition magic 8.0 but pm8.0 didn't support it.
Any suggestion is welcome.
SlimTech
slimTech is offline
Old 18-06-2008, 08:29 PM   #2 (permalink)
TheSaint
NucleusKore's Avatar
Default Re: Pen Drive capacity has decreased by 480MB
Boot system from Gparted live cd with pendrive plugged in and delete all partitions
http://gparted.sourceforge.net/
http://www.neville.in
http://www.linuxrocks.in
"The Future Is Open"
NucleusKore is offline
Old 18-06-2008, 09:27 PM   #3 (permalink)
-----ATi-----
nvidia's Avatar
Format the entire drive completely(Not quick format) and then try.
And stay away from Partition Magic.. It can make things worse..
http://twitter.com/akshayms
nvidia is offline
Old 18-06-2008, 10:14 PM   #4 (permalink)
TheSaint
Originally Posted by nvidia View Post
..... and then try.
It is also jokingly known as Partition Tragic.
Old 18-06-2008, 10:30 PM   #5 (permalink)
Legen-wait for it-dary!
dheeraj_kumar's Avatar
Partition Tragic
Lol! didnt know that!
Anyway, you can try a low level format, that can fix ANY logical issue on the drive.
dheeraj_kumar is offline
Old 19-06-2008, 05:11 PM   #6 (permalink)
-----ATi-----
nvidia's Avatar
Lol.. Thats so true... My had disk was totally messed up after using it..
nvidia is offline
Old 21-06-2008, 12:18 AM   #7 (permalink)
boot from cd , with pendrive plug in , deleat all partition and recreat it
ashutosh.sanny is offline
Old 25-06-2008, 02:31 PM   #8 (permalink)
Climbing..........
slimTech's Avatar
thanks to u all
as told by NucleusKore, I couldn't get the Gparted live cd. Only I was able to downloaded a file gparted-0.3.7.tar.bz2 from http://gparted.sourceforge.net/ that contained c++ source files. Please suggest.
I tried with the bootable cd, but it only displayed the partition that was available in the pendrive. I want to recover the disk space that i have lost.
as told by dheeraj_kumar, the low level format might work but i don't know how to do it.
Please suggest way to do low level format.
slimTech is offline
Old 26-06-2008, 03:26 AM   #9 (permalink)
I've heard of some people having problems after using Partition Magic, but to present a balanced view -
I've been using PM8 for years now to partition, format, resize, change file system, change cluster size, hide or unhide partitions, etc., etc. of hundreds of hard disks. Not once have I ever had any problem with it. It's a versatile tool and careless or inexpert use can certainly cause problems, but judging from my own experience, I don't think it's a crappy piece of software.
pimpom is online now
hard drive capacity of ipod classic Ramakrishnan Mobiles and Tablets 4 01-05-2008 09:01 PM
More RAM Decreased Performance ??? rsingh Hardware Q&A 2 06-03-2008 01:18 AM
how to utilize pen drive for maximum capacity? chicha QnA (read only) 15 04-02-2008 03:28 PM
Multiple HDD with small capacity or one HDD with large capacity? Anindya QnA (read only) 2 19-05-2007 02:22 AM
pen drive shows less capacity... gauravakaasid QnA (read only) 2 25-07-2005 11:18 AM
