Old 17-06-2008, 10:18 PM   #1 (permalink)
Default computer starts automatically
hi friends!
I am facing a problem with my computer, it starts automatically (after shutting down) when the ups is on. Can anybody tell me what the problem is and what I need to do?
peyoush_thakur is offline
Old 17-06-2008, 10:29 PM   #2 (permalink)
Violent serenity.
Psychosocial's Avatar
Default Re: computer starts automatically
change the UPS
Psychosocial is offline
Old 17-06-2008, 11:51 PM   #3 (permalink)
There is a option in BIOS under power management I believe, where you can set the option to either power on or power off PC after a power failure. Check that.
pawsingh is offline
Old 18-06-2008, 12:45 AM   #4 (permalink)
Lets Do It!
amrawtanshx's Avatar
Yes u are right.
By enabling this option u dont need to press ur CPU button.
Reset this.
"Now you're looking for the secret... but you won't find it, because you don't really want to know. You want to be fooled."
amrawtanshx is offline
Old 18-06-2008, 12:48 AM   #5 (permalink)
mayanksharma's Avatar
could be either PSU / UPS fault! Crosscheck accordingly and then see.
mayanksharma is offline
Old 18-06-2008, 01:34 AM   #6 (permalink)
Does your PC start randomly (i mean anytime) or when you turn on the UPS?
pawsingh is offline
Old 22-06-2008, 10:12 PM   #7 (permalink)
My PC starts automatically only if, after shutting it down, I don't turn off my UPS. If I turn on UPS and don't turn on the PC then it doesn't start by itself.
Folder opens automatically when win xp starts... sushantasarkar Software Q&A 4 17-10-2006 08:49 PM
spyware doctor starts automatically on net connection nix QnA (read only) 4 27-02-2006 12:46 AM
Computer Turned off & not Starts debiprasad_sahoo Hardware Q&A 4 24-02-2006 08:01 PM
HOW WindowBlinds 5 Starts Automatically at each startup! Vishal Gupta Software Q&A 4 02-12-2005 03:09 PM
computer(win xp) starts dialing automatically vikas_r_s Software Q&A 4 29-01-2005 07:10 AM
