Old 17-06-2008, 07:09 PM   #1 (permalink)
Call me Sumit
esumitkumar's Avatar
Default want to upgrade PC..max budget 22k .plz help
Hello
My frnd wants to upgrade his system . Budget is max 22000/- .Things to be bought are :
1. 19" LCD
2. Processor
3. Motherboard
4. RAM
5. Cabinet
Please suggest the confg in this max possible budget.
Thanks
Sumit
esumitkumar is offline
Old 17-06-2008, 07:30 PM   #2 (permalink)
Violent serenity.
Psychosocial's Avatar
Default Re: want to upgrade PC..max budget 22k .plz help
hmm.....
u can get Dell 19"
E8200
IP35e
2GB DDR2 800MHz
Zebronics Lava
Psychosocial is offline
Old 17-06-2008, 09:36 PM   #3 (permalink)
Lets Do It!
amrawtanshx's Avatar
Dell 198WP @ 9.5 k
Motherboard.. ABit .... IP35-E @ 5400.
Processor ... Core 2 Duo... E 4500 @ 4.6 k
RAM ... Transcend 2GB DDR2 @ 800MHz @ 1950
I-Ball i648 @ 1400
"Now you're looking for the secret... but you won't find it, because you don't really want to know. You want to be fooled."
amrawtanshx is offline
Old 17-06-2008, 09:39 PM   #4 (permalink)
Violent serenity.
by amrawtanshx
u are better off saving and buying E8200 for future proofing
Plz help, for upgrade budget: 15~16k LoBo Hardware Q&A 17 15-06-2007 02:02 PM
AMD system upgrade..err??no u all bored of upgrade forums but pls do help me...!! karthik316_1999 Internet & WWW 11 18-07-2006 08:10 PM
graphic card upgrade(PCI) or motherboard upgrade? thetopcyborg Graphic cards 5 13-01-2006 02:32 PM
Plz Suggest upgrade for budget. Tommy Vercetti Hardware Q&A 4 06-12-2005 02:58 PM
Nforce4 out of budget - What to upgrade to? geek QnA (read only) 2 08-12-2004 10:00 PM
