Old 17-06-2008, 04:38 PM   #1 (permalink)
Question Motherboard Problem
I have a P4 with 1 GB Ram and Intel 845G Chipset Motherboard.
When I switch on the computer, it goes upto the welcome screen and automatically shutdowns. When I again switch on the computer, it starts beeping with one long beep and one short beep for sometime and again shutdowns. I don't understand what's the problem of it. Please give me a solution for it.
sudheer919 is offline
Old 17-06-2008, 07:31 PM   #2 (permalink)
Violent serenity.
Psychosocial's Avatar
Default Re: Motherboard Problem
RAM
Psychosocial is offline
Old 17-06-2008, 07:34 PM   #3 (permalink)
check it with another ram ur problem will be solved
kanewilliam is offline
Old 17-06-2008, 09:30 PM   #4 (permalink)
Lets Do It!
amrawtanshx's Avatar
Ur RAM module is misplaced.
Open ur cabinet and adjust it.
"Now you're looking for the secret... but you won't find it, because you don't really want to know. You want to be fooled."
amrawtanshx is offline
Old 20-06-2008, 04:08 PM   #5 (permalink)
Question Re: Motherboard Problem
I have cleaned the ram. The ram is working with the other system and is adjusted correctly. Still I face the same problem.
Old 20-06-2008, 07:28 PM   #6 (permalink)
dhanusaud's Avatar
may be there is a problem with your os, repair your os & give a try.
BTW, I am sure this is symptoms of bad RAM modules.
dhanusaud is offline
problem with motherboard sumansaurabh CPU / Motherboards 1 29-03-2008 06:25 PM
Problem with my motherboard. zegulas CPU / Motherboards 3 29-10-2007 09:40 AM
problem with motherboard vivekbabbudelhi Hardware Q&A 6 28-06-2007 10:03 PM
Motherboard Problem saigalp Hardware Q&A 1 17-05-2007 03:46 PM
